Sears red jack modification
Old Apr 15, 2012 | 12:47 AM
  #381
scottystreetbob's Avatar
scottystreetbob
Default red jack mod
thanks for the vid, put pad on outside of the frame but the front bar hits the jiffy stand while putting jack under the bike how did u get around this? i think ill jus cut it off
Old Apr 15, 2012 | 05:43 AM
  #382
SC-Longhair's Avatar
SC-Longhair
No, I didn't cut it off. I bump the kickstand, then pull the jack back just a hair. Begin jacking the the bike.
Old Apr 15, 2012 | 10:08 AM
  #383
Kaycee's Avatar
Kaycee
Just picked up a sears jack last week for $79. on sale ,did the mod and wished I would of done this yrs ago.I push the jack in at a slight angle seems to work good this way and does not hit anything.Thanks for the tip
Old Apr 20, 2012 | 05:10 PM
  #384
soupknotzee's Avatar
soupknotzee
Default Very Low 02 Dyna Lift Help
So I have a 02 Dyna with 11" progressive shocks and a FLST front end with 2" lowering springs and as you can imagine its a bear trying to get my red craftsman under the bike.
I have done the mod in this thread and even took the rubber pads off of the lifting blocks to gain 1/4" lower height but still cant get it under the bike without putting it up on a 2x or getting a small floor jack under the front frame (hate doing this)
My question is after 3 years of discussion, what is the general consensus on further mods to get this lift even lower to fit under really low bikes? I know it was mentioned hogging out or relocating the lifting block holes and also replacing the solid metal wheels with smaller diameter (havent found these)
I can see a number of things I could modify/change but just wondering what might be the easiest to reach my goal with least amount of effort and $
Also worth mentioning that it still seems like my jack even with mods is still hitting the jiffy stand when pushing it under the bike?
I would really like to make it work and not drop big coin on a J&S or Pitbull, which I am still not even sure would work with my very low bike.
I guess if all else fails I could go with the HF High Position Motorcycle Lift which seems to really hug the ground...
http://www.harborfreight.com/high-po...ift-99887.html
Old Apr 20, 2012 | 05:23 PM
  #385
SC-Longhair
The mod vs a really lowered bike is no go. There is a price you pay for lowering.
Old Apr 20, 2012 | 06:09 PM
  #386
DCLXVI's Avatar
DCLXVI
I made a ramp out of two pieces of 2x6 lumber nailed together. I place it in front of the rear tire then drive the bike up on it. This gives me plenty of clearance for the jack.
Old Apr 20, 2012 | 07:39 PM
  #387
soupknotzee
Yah been doing that for years. Its a pain in a small garage and for one person.
Old Apr 28, 2012 | 10:01 PM
  #388
20RoadGlidin's Avatar
20RoadGlidin
Does anyone know if this lift will lift a Dyna without modification?
Old Apr 28, 2012 | 10:03 PM
  #389
8541hog's Avatar
8541hog
Of course it will, but you will need adapters due to the "skid plate" on the bottom of the Dyna frame.
Old Apr 28, 2012 | 10:05 PM
  #390
20RoadGlidin
The same adapters that are used on the sears red jack? The High position lift appears to be wider, so I thought maybe that it wouldn't need anything special. Maybe I'm confused.
