Sears red jack modification
Old Sep 11, 2012 | 07:53 PM
  #481
mass-oilman's Avatar
mass-oilman
I tried this mod and it worked like a charm. The jack is cheap but it does the job
Old Jan 30, 2013 | 03:44 PM
  #482
floridamk's Avatar
floridamk
Just got a Sears red jack and did the mod, works perfect.
Old Feb 1, 2013 | 03:37 PM
  #483
Kevin714's Avatar
Kevin714
It's Sears and red, and I just ordered it. Hope its the right one.
http://www.sears.com/shc/s/p_10153_1...ku=00950190000
Old Feb 1, 2013 | 04:14 PM
  #484
lo-rider's Avatar
lo-rider
That's the one.
Old Feb 1, 2013 | 04:56 PM
  #485
Kevin714's Avatar
Kevin714
Originally Posted by lo-rider
That's the one.
I like stuff that's cool.
Must be shipping from FL. ordered it today and the site said I'd get it Monday.
Old Feb 2, 2013 | 10:18 AM
  #486
ynots's Avatar
ynots
I had mine for 2 yrs now. No complaints. Pd $100.00 cant see paying more when it does the job. I do have to remove the rubber kick stand bumper otherwise it gets knocked off
Old Feb 2, 2013 | 12:49 PM
  #487
03Custom883's Avatar
03Custom883
I have the same jack but my FXDL is a 2003 will this mod still work or is it only for newer frame dynas?
Old Feb 2, 2013 | 12:50 PM
  #488
lo-rider's Avatar
lo-rider
You'll like it.
Old Feb 2, 2013 | 05:06 PM
  #489
02fx4dude's Avatar
02fx4dude
Works pretty good for dropping and installing rear axles too...
Old Feb 4, 2013 | 08:07 PM
  #490
Kevin714's Avatar
Kevin714
Jack came today. I bought all grade 8 bolts and nuts.
When I was drilling out the support parts I was surprised how soft the metal was. After I cut the cross bar off I cut it into 3 pieces a bit over 2 5/8" and ground them down to fit inside the lift support things where the bolts went through. The cross bar was only long enough for 3 spacers, but I found a similar size piece of stock in the junk box for the fourth one. I didn't read all the thread so this my be a standard thing to do. I just figured the support things might bend when I torqued the 1/2" bolts down.
I couldn't find any 1/2" spacers that looked strong at all, so I used four 3/4" nuts as my spacers. They were just about exactly 1/2" thick.
Jack works too good.
