Sears red jack modification
Old Feb 6, 2013 | 06:01 AM
  #501
pthauvet's Avatar
pthauvet
Originally Posted by lo-rider
It looks as if you have to run the bike up on blocks to get enough room to slide the jack under?
Yes, no choice my bike is lowered front and back plus I am running an Avon in the back that lowers it even more,
Old Feb 6, 2013 | 09:40 AM
  #502
lo-rider's Avatar
lo-rider
Plus you've stacked all that stuff on top of your lift.
Old Feb 6, 2013 | 10:43 AM
  #503
jmeiers's Avatar
jmeiers
What's the big deal with the HD adapters? I use the Yellow Craftsman aluminum jack and have no issues with the HD adapters or stability. My bike has been up in the air for the last month and no issues and I have rolled it all over the place too.
I understand the Red jack needs some modifications because it does not sit as low and wide as the Yellow jack but I don't think the HD adapters are crap. They do what they were designed to do, level the bike on a proper jack. I don't think they should be labeled as crap because of the jack's limitations.
Don't get me wrong though, if after doing this modification to the Red jack, you no longer need the HD adapters, then that's a good bonus.
Old Feb 6, 2013 | 12:11 PM
  #504
02fx4dude's Avatar
02fx4dude
There's nothing wrong with the adapters if you want to use them (debatable). However, some people, myself included, do the mod to lift the Dyna's without the adapters. Has nothing to do with the jacks limitations.
Old Mar 16, 2013 | 03:02 AM
  #505
Mikewoodmp's Avatar
Mikewoodmp
1st Gear
Default Lil help.....
Hey brother I just came across the mod for the craftsman lift. I'm trying to figure out wich bolts are safe. I went to the mans Walmart "home depot" and they had zinc galvanized and stainless. Which do I need? They didn't seem to have info on the grade? Also only about an inch of the bolts were actually threaded is that ok?
Old Mar 16, 2013 | 04:47 AM
  #506
03Custom883's Avatar
03Custom883
I used grade 8.
Old Mar 16, 2013 | 05:47 AM
  #507
Mikewoodmp's Avatar
Mikewoodmp
1st Gear
That's my Selina what material is grade 8
Old Mar 16, 2013 | 05:48 AM
  #508
Mikewoodmp's Avatar
Mikewoodmp
1st Gear
I meant delima. Hahah
Old Mar 16, 2013 | 07:04 AM
  #509
SC-Longhair's Avatar
SC-Longhair
Grade 8 bolts are usually gold-colored.
Go to a real hardware store. as far as how much is threaded, an inch or so should be fine. You just want to snug it up not too tight or the pads will bind and the jack won't work correctly.
notice the color? You can also tell by the marking on the head of the bolt.
Just searched homedepot.com...they do have grade 8:
http://www.homedepot.com/webapp/cata...gry=Search+All
Old Mar 16, 2013 | 08:04 PM
  #510
Mikewoodmp's Avatar
Mikewoodmp
1st Gear
Default Thanks again
Went with stainless bolts. They said they were real strong? Lets hope. Tried without first and I can see what everyone is talking about. Good jack though. Now to paint the shocks. Just the stability alone is worth it. Not to mention day bye bye to those god forsaken HD lift accessories.
