Sears red jack modification
Old Jul 5, 2012 | 07:50 PM
  #461
8541hog's Avatar
8541hog
Originally Posted by lo-rider
It isn't shear loads, at all, that are the concern; it's bending loads way out at the ends of those long bolts. Have it your own way, but I am only trying to discourage anyone else from copying a deficient and potentially unsafe plan.
On that we are in complete agreement.
Old Jul 5, 2012 | 08:12 PM
  #462
Puffdaddy's Avatar
Puffdaddy
Puff--This whole thread is about modifying YOUR jack to better accommodate our bikes. Go to page 1
I have no idea why you have YOUR in uppercase. It is the "SEARS RED JACK MODIFICATION" thread. I have a red Sears jack that look just like all those posted, but it is slightly older, and has narrower lift arms. If you had read all my posts you would understand the issue I had (past tense). The pics cleared it up.
As a note, I stated the lift arms are narrower. The spacers wouldn't make a bit of difference since the lift arms are hitting the jiffy (as stated in my post).
New jack is the only remedy I can see
This is a GREAT thread, but it sure has been controversial.....
Old Jul 5, 2012 | 08:24 PM
  #463
FXDWG12's Avatar
FXDWG12
I can't disagree. But I have no recourse either. As the results of conversations with friends, I will add this:
If you use a cantilever design. Or make any modifications to a lifting device. - USE AT YOUR OWN RISK.
How wide is that jiffy stand?
Old Jul 5, 2012 | 08:30 PM
  #464
Puffdaddy's Avatar
Puffdaddy
As wide as everyone else's stock stand. If I straddle the bike and put the stand up, it will go under the bike. Risky situation I'm trying to avoid
Old Jul 5, 2012 | 10:13 PM
  #465
lo-rider's Avatar
lo-rider
There's no need to straddle the bike. As you slide the jack underneath, grab the closest handlebar grip and pull the bike a little more upright. Bada-bing! The jack easily slides under.
Old Jul 6, 2012 | 05:44 AM
  #466
SC-Longhair's Avatar
SC-Longhair
Puff, it almost seems like you may think the fat bob is different than other dynas in this thread. I can assure you it is the same. I used my jack to pick up my buds '12 fat bob without issue.
It's been noted that some members were trying to lift the bike from the kickstand side. Not the correct way to lift a bike, at least not a dyna.
Old Jul 6, 2012 | 05:50 AM
  #467
SC-Longhair
Originally Posted by chris h.
Whelp, I went for it. Measured the sporty first and it seemed like it would work. Good news, it totally works on both the sporty and the dyna. Definitely appreciate this thread and this is why I love this forum. Here's a couple pics:
I had a feeling it would be fine but without a sporty handy to test I couldn't say for sure.
The jack mod; dyna, earthquake, sportster-approved.
Old Jul 6, 2012 | 10:34 AM
  #468
soupknotzee's Avatar
soupknotzee
Ill be damned. Mine is also 12-11/16"
Up to now I was under the impression my modified jack was still not working because of how low my bike is.
Thanks for the pic 8541hog, I think i have figured why the lift arms hit my jiffy! My Sears jack is only 12 11/16" inches from outside to outside the lift arms instead of the 13 7/16th" in your pics. I didn't get this jack new so I have no idea how old it is. They must have changed the design of the jack since mine was made.
Wonder if I should just get a new jack at this point...
Old Jul 6, 2012 | 11:04 AM
  #469
lo-rider's Avatar
lo-rider
As far as I know, they're all that size.
Old Jul 21, 2012 | 09:22 AM
  #470
QC-RAIDERS-91's Avatar
QC-RAIDERS-91
I got a 06 lowrider, my modified jack is 18'' wide I can't slide it underneath perfectly is it because the lowrider is lower than other dyna(if so do I only have to grab one handlebar and get the bike more upright?), second question should I put the head of the bolt inside or outside (outside is like in the quoted picture mentionned higher in this page ?)
