NEED ADVICE...Flywheel issue
Old Mar 20, 2010 | 07:21 PM
triplexjd's Avatar
triplexjd
Stage IV
Default NEED ADVICE...Flywheel issue
I have a 2007 superglide with only 12000 miles. The oil pump went out and when that happened something also damaged the flywheel. i was told that the run-out was 20 which spec for hd is 12. I do not have the 2 grand to fix this problem. I need to know what will happen if i ride it...short distances. My school is 13 miles from my house and my bike gets a lot better gas than my suv....I really pissed this happened 2 months after my warranty went out so I have to pay for all the repairs.
Old Mar 21, 2010 | 12:15 AM
archergodwin's Avatar
archergodwin
The new 96" can have issues with the crank/flywheel. I'm guessing that the crank took your oil pump out, and not visa versa.
If your oil pump went out.... why would you even consider starting it, much less ride it?
All this damage was happening before your warranty was up... I would push the issue with the dealer and make sure the MoCo knows as well.
Old Mar 21, 2010 | 10:50 AM
triplexjd's Avatar
triplexjd
Stage IV
the only time that it was rode was to get it back home which was about a 3 mile distance from when the oil light came on it has moved since then and its been sitting at the mechanics house for the past 3 months.
Old Mar 21, 2010 | 11:53 AM
archergodwin
That sucks stagnant pond water man.... so probably not 'too' much damage then. Again tho.... push the issue.
0.012 runout is BS. It is my opinion HD opened up the specs on the runout, to avoid a class action lawsuit.
Old Mar 21, 2010 | 12:24 PM
redrubicon2004's Avatar
redrubicon2004
Do not ride it! You will cause more damage. Get it fixed. Your mechanic wants $2k to fix it? Too bad you dont live near me!
Did you ride it at low RPM often?
Old Mar 21, 2010 | 12:33 PM
Faast Ed's Avatar
Faast Ed
The flywheel is junk. That motor "is over" until you get the crank trued and welded.
Do not replace with a stock crank, unless you want to repeat this nightmare.
Old Mar 21, 2010 | 03:30 PM
triplexjd's Avatar
triplexjd
Stage IV
so what would be a better replacement
Old Mar 21, 2010 | 03:46 PM
redrubicon2004
Cheap fix= True and weld
Better fix= Get a SE or Jims wheel and have it welded
Best option, call Darkhorse and talk to them.
Old Mar 21, 2010 | 03:51 PM
Faast Ed's Avatar
Faast Ed
Here is one very reputable option:
http://www.darkhorsecrankworks.com/
Once welded, way less chance for problems. They balance them well too!
martin10
Milwaukee Eight (M8)
44
Sep 13, 2021 05:14 PM
skybox ed
2014-2024 Touring Models
87
Mar 11, 2015 04:40 AM
babyray
Sep 2, 2010 11:12 PM
gandy dancer
Oct 27, 2008 03:51 PM
LAZYBOY
Aug 19, 2006 07:47 PM
