Swapping out PCV for TTS
Old May 12, 2010 | 11:54 PM
Bikepusher's Avatar
Bikepusher
Thumbs up Swapping out PCV for TTS
Going for a dyno tune at the Cycle Doctor in Costa Mesa, they told me TTS works a lot better than the PCV, can't wait to see the results.
Old May 13, 2010 | 12:16 AM
SC-Longhair's Avatar
SC-Longhair
From what I've been reading is that you pretty much won't need to dyno tune with the TTS as it will create an optimized map w/ your assistance.
Old May 13, 2010 | 05:54 AM
ColdCase's Avatar
ColdCase
TTS is certainly better, tuners like the extra programming control and predictability, but by a lot over a dyno tuned PCV... I dunno.... unless one or two MPG, HP, or ftlb torque is a lot to you.
It will be an interesting seat of the pants comparison, however.
Old May 13, 2010 | 07:47 AM
OutlawBagger's Avatar
OutlawBagger
What kinda power is it making now? Whats the price difference between the TTS and PCV? I've got a PCV and very happy with it. If it only make a little difference is it really worth the money?
Old May 13, 2010 | 09:03 AM
SC-Longhair
The tts is not a piggyback system. it overwrites to the ecm directly. You can tune it yourself.
(yes, I've been doing oodles of research and the more I read, the more I want one.)
I just read a story on hotbike.web where they used a tts on a custom build. They then used the vtune software to tune it. Afterwards they put the bike on the dyno for further tuning. They were only able to get +1hp out of it which means the vtune software worked perfectly as it should have.
Old May 13, 2010 | 09:27 AM
SURFOR Chop's Avatar
SURFOR Chop
Vic -
You should also take a look at ThunderMax with Auto Tune ... does pretty much the same thing ... not sure how they compare price-wise ....
Got a pretty good deal on my T-Max from a forum member who was taking it off to install TTS, though ... so, maybe that says something .... (So I'm pretty sure I paid less than TTS costs ....)
(He said the tuner he is using doesn't know how to tune T-Max, but can tune a TTS ....)
R/
'Chop
Old May 13, 2010 | 09:50 AM
SC-Longhair
Originally Posted by SURFOR Chop
Vic -
R/
'Chop
I've been following several threads regarding both, including your's. You should see my shopping list when I become one of the employed again.
Old May 13, 2010 | 10:10 AM
yso191's Avatar
yso191
I don't think the value of Dyno tuning with the TTS is necessarily hp & tq. I gained a little in that area, but not enough to warrant the $500 price tag. What I did gain is a great hp & tq curve, no pinging, just smooth steady power all the way. As long as I am above say 2700 rpm I can just pin the throttle and the bike does what it is supposed to do.
Steve
Old May 13, 2010 | 12:26 PM
Redbeard's Avatar
Redbeard
If your dyno guy prefers a certain tuner, then it's probably worth the swap for best results.
Great looking bike, Bikepusher! What rear shocks are you using?
Old May 13, 2010 | 12:32 PM
SC-Longhair
That can get pretty costly, don't ya think?
I mean what if we transfer that idea onto an auto-mechanic who prefers to work on mercedes but you own a chevy. Does that mean you have to sell the chevy and buy a mercedes?s
