another handlebar swap question?
Old May 14, 2010 | 09:05 AM
krazhik's Avatar
krazhik
Default another handlebar swap question?
I have been searching and searching and searching the web and this site for information on handlebar swaps --------- I have a 07' bob that needs a new look when I go home on my next leave ----- I have 6 inch risers and sportster drag bars to install as well as mount my front sigs on the forks. Can you guys point me in the right direction for a detailed how to on swapping bars -- I know its here somewhere around here ---- ohh and while I am at it for anyone who has forwards controls and drag bars -- hows the difference in the handling??? thanks everyone!
Old May 14, 2010 | 11:06 AM
shimmon's Avatar
shimmon
Wiring extension for apes:
HD Wire Extension Kit 72137-03
http://www.designsbynovello.net/
https://www.hdforums.com/m_1328001/tm.htm - Step by Step
https://www.hdforums.com/m_1180682/tm.htm
https://www.hdforums.com/m_1839302/tm.htm
Installing APE’s
https://www.hdforums.com/forum/dyna-...e-install.html
https://www.hdforums.com/forum/dyna-glide-models/88710-my-ape-install.html
Internal wiring bars
https://www.hdforums.com/forum/dyna-...-new-pics.html
https://www.hdforums.com/forum/dyna-...al-wiring.html
ext: http://www.jpcycles.com/productgroup...9-9D98ED920065
HERE IS A FEW LINKS TO GET YA STARTED. BUT REALLY THIS SHOULD BE AN EASY SWAP, WONT NEED TO CHANGE OUT CLUTCH, IDLE, THROTTLE, AND BRAKE LINE UNLESS YOU WANT TO SHORTEN THEM TO CLEAN UP THE LOOK. IF YOUR NOT WANTING TO SHORTEN CABLES IS AS SIMPLE AS REMOVED GRIPS AND CONTROLS, REMOVE STOCK BARS, INSTALL NEW BARS, INTERNAL WIRE BARS, AND INSTALL GRIPS ON CONTROLS. IT SEEMS DAUNTING AT THIS TIME, BUT ONCE YOU START IT WILL ALL FALL INTO PLACE. ANY MORE QUESTIONS JUST ASK. I DID MY APE, AND A BUDDIES T BAR, INSTALL A FEW MONTHS AGO, SO ITS KINDA FRESH IN MY HEAD. HARDEST PART IS REMOVING THE PINS IN THE HANDLEBAR CONTROL CONNECTORS UNDER THE GAS TANK.
Old May 14, 2010 | 12:14 PM
krazhik's Avatar
krazhik
thanks man --- thats awesome -- should be all information I need man..
GittinThere
Sep 19, 2018 12:35 PM
CWS
Jan 26, 2016 10:33 PM
Rnt77
Jun 10, 2013 02:43 PM
jay72
May 31, 2012 03:35 PM
ShadowSoldier777
Aug 10, 2010 08:54 AM
