Combination Speedometer/Tachometer
Old May 15, 2010 | 04:57 AM
HDRusty's Avatar
HDRusty
Default Combination Speedometer/Tachometer
I am thinking about picking up the Combination Speedometer/Tachometer from HD for my 2010 WG (part number 74676-09). Does anyone know if it has all the same idiot lights as the other one? Does it have the 6th gear light? I cant seem to tell HD's web site.
Old May 16, 2010 | 09:11 AM
ggadwa's Avatar
ggadwa
Default Combination Speedo/Tach
I have a 2009 FXDC and I installed the Combo unit.....it has all the same idiot lights etc....I like having a Tach.....but the real deciding factor was my Wife insists she prefers to drive by a Tach....who am I to argue.
GARY
Old May 16, 2010 | 10:13 AM
oldmanwayne's Avatar
oldmanwayne
You may want to look at the size of the numbers on the combo- I had this on my RK an found it much harder to read when I glanced down- fwiw...
Old May 16, 2010 | 10:25 AM
joflewbyu2's Avatar
joflewbyu2
I was thinking of making that mod too. Only using the Digital speedometer with analog tachometer for easier viewing. Below is the pic of the part # 74723-10
Attached Thumbnails Combination Speedometer/Tachometer-74723-10-combo-dig.jpg
Old May 16, 2010 | 10:34 AM
transman's Avatar
transman
I did on my 08 " Superglide .
Old May 16, 2010 | 10:41 AM
Centerline's Avatar
Centerline
It has all the bells/whistles of OEM (incl 6th gear ind), with addition of the tach and selectable LED colored lighting.....
Old May 16, 2010 | 11:58 AM
wideglidebob's Avatar
wideglidebob
did it on my 05 wideglide and all functions are same i did the old school one that is white faced love it, of course my bike is white so really sets dash off
Old May 16, 2010 | 12:07 PM
lo-rider's Avatar
lo-rider
Default speedo/tach
I see you have it on an '09. What electrical changes did you have to make, if any, to get the tach and gear indicators to work? This seems like a terrific upgrade. They ought to show all the gears.
Old May 16, 2010 | 03:54 PM
Triig's Avatar
Triig
Just a heads up for the OP, 74676-09 will not fit a 2010 wide glide. That is a 5" speedometer and the 2010 wide glide has a 4". You'd have to get 74735-09 unless you change some things. Not sure what all would be involved in that.
Bamaboy42
May 31, 2017 06:19 PM
arod6
Nov 19, 2015 01:21 PM
WensGlide
General Topics/Tech Tips
Nov 20, 2008 09:53 PM
OCBINVA
Jun 29, 2007 12:46 PM
icecaps
Mar 24, 2007 03:41 PM
