Better than ever.
Old May 20, 2010 | 01:14 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Default Better than ever.
Finally switch out my front dunlop with a Metzeler ME880 to match the rear. With those tires, 30 tooth trans pulley, Barnett clutch spring, 25* injectors and a Thunderheader my bike has never felt or sounded better.
Old May 20, 2010 | 05:56 PM
jaysonL's Avatar
jaysonL
Right on . Those Metzelers rock !!!
Old May 20, 2010 | 11:43 PM
macnab_sf's Avatar
macnab_sf
What diff did the 25 injectors make? (I have been thinking about this, I understand the swap is pretty easy.)
Thanks,
Dan
Old May 21, 2010 | 07:41 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Thanks,
Dan
I had starting problems like excessive cranking and occasional stalling after start up. I also had terrible surging in first gear. I tried for over a year to tune these problems out with the Tmax and couldn't do it. The 25* injectors fixed the problems.
It was a 20 min. job swapping the injectors. The service manual tells you to remove the tank and the whole induction unit. This is not necessary. Remove the horn and mounting bracket then from the primary side of the bike using a socket extension you can remove one bolt and the fuel rail assembly will come out. Then the injectors just pop out, pop in. I put off this job for a while cause I thought it would take time and be a PITA, but it was super easy. I watched ebay for months and months looking for injectors and finally got 2 for $40 including shipping.
Old May 21, 2010 | 08:44 AM
rounder's Avatar
rounder
cool, I love it when a plan comes together.
Old May 21, 2010 | 08:47 AM
GeorgeJ's Avatar
GeorgeJ
The metz's make a world of difference. Did you go with a 110?. That made a difference for me as well.
George
Old May 21, 2010 | 08:58 AM
HOGRIDA_06's Avatar
HOGRIDA_06
George
Nope, stayed with a 100. I like how it looks under my lowered fender.
Old May 21, 2010 | 09:19 AM
GeorgeJ's Avatar
GeorgeJ
Nice - I gotta do that to the fender. After converting to a 49mm front end I noticed the fender is a lot higher than my old 39mm set-up. Is it just a matter of elongating the holes on the fender so it drops?
Thanks - George
txphatboy
Jul 1, 2017 09:32 PM
Dirt Bagger
Jan 19, 2014 03:08 PM
TXSailor
Exhaust System Topics
Jan 3, 2012 01:42 PM
wydopn231
Apr 19, 2008 10:54 PM
T.C
Aug 15, 2006 02:06 AM
