installing forward controls on 07 Super Glide?
Old Aug 25, 2006 | 01:33 AM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Default installing forward controls on 07 Super Glide?
I heard you have to remove the inner primary to do this?
Anyone here done this project?
Thanks
Old Aug 25, 2006 | 02:24 AM
bobcowan's Avatar
bobcowan
Default RE: installing forward controls on 07 Super Glide?
The "proble" is the shifter shaft that extends through the inner and outer primaries. It's a one piece design. There's no way to unbolt the arm from the inside end of the shaft. To remove it, you have to remove the inner primary.
BUT, you don't actually have to remove the arm. You can leave it in place. The outside stub can be covered with a chrome cover available from KA. You could just leave the shaft to swing around free. But it will bang on the inner primary and make annoying noises. I saw somebody had made a small bracket to hold it in place. One end bolted onto the shifter shaft, and one end to an existing nut on the engine case. Pretty slick.
Old Aug 25, 2006 | 03:21 AM
rj164's Avatar
rj164
I had someone do it, when I had the 5000 mi service, here my 05 super glide, everyone has a different look, and idea, have fun with it.
[IMG]local://upfiles/10881/57D3B1EE66FA48AA9658D38BC81D6E60.jpg[/IMG]
Old Aug 25, 2006 | 03:28 AM
jkenosh's Avatar
jkenosh
this is a pretty easy job, you should be able to handle it in around 1 hour, softails are harder to do because of the rear brake master cylinder but dynas are easy.
Old Aug 25, 2006 | 10:36 AM
Mascman's Avatar
Mascman
Buy the kit for 2005 and earlier.
I just installed this kit on my 2006 and it is pretty straightforward.
The kit comes with the cover for the shifter shaft...it's held on by a set screw.
It also has the bracket to bolt the other end to one of the bolts in the engine block.
I really didn't want to take the time to remove the primary covers just to get the shift shaft out. My thinking is that if I sell the bike, it's a quick swap back to the mid controls...or possibly if you had an injury and had to switch to the mids for a while to keep riding it is much simpler.
I got the HD kit from www.mandmcycles.com for $267.00 shipped to my door.
Old Aug 25, 2006 | 10:46 AM
jt1965's Avatar
jt1965
Ride the bike here to Illinois and I will install them for you. You just have to buy the beer.
I have grown real fond of Geuniss.
Send me a PM and I will see if I can lead you down the right path.
Old Aug 25, 2006 | 08:29 PM
soup48's Avatar
soup48
In the installation kit, the chrome cap comes with the packge. AS was said before. Besides I removed the forwards from my '04 FXD and installed it to my '06 FXDCI, the only thing I had to do was buy the shifter rod for the '06.
Old Aug 26, 2006 | 11:43 PM
KeithB's Avatar
KeithB
Has anyone done this on the 07 without removing the primary? The guy at my dealer still says it has to be removed. but looks to me like it could be done without.
Thanks
Old Aug 27, 2006 | 02:35 AM
Mascman's Avatar
Mascman
He may be talking about the 2006 and newer kit, which is the one designed to remove the shift shaft.
Get kit #49080-03 and leave the shift shaft in...and it costs less too.
Old Aug 27, 2006 | 10:40 AM
KeithB's Avatar
KeithB
The 07 has a new tranny, you sure the older kit will work on the 07? thanks
