Help with noise/vibration
Old Aug 20, 2010 | 03:03 PM
dynarider925's Avatar
dynarider925
1st Gear
Default Help with noise/vibration
I have a 2007 super glide custom that I bought used and is my first Harley. There has been some engine mods by previous owner.
When it is hot outside and the bike has been run for a while there is a noise with vibration on coasting in any gear. most noticable at 45-50.
I can hear a low howl noise and feel the vibration in the engine, it will go away if clutch is let out to put a load on the drivetrain.
This is not a tire problem, I checked on many surfaces.
Can the belt cause this type of noise or should I be looking at transmission or primary drive?
Otherwise the bike runs great, just annoying when warm, I have gone 2600 miles and it hasn't gotten better or worse.
Thanks for any ideas..
Old Aug 20, 2010 | 03:09 PM
KingenCo's Avatar
KingenCo
I had a noise problem on my fat bob a week or two ago. The belt was too tight. You could hear it regardless if a load was applied or not. What you're describing doesn't sound like a belt.
Old Aug 20, 2010 | 03:23 PM
cornishman's Avatar
cornishman
Try the belt tension, you should be able with two fingers and moderate ease turn the belt to 45 degrees measured middle distance between the two pulley,s. Thats unless you have a Harley belt tensioner.
Old Aug 21, 2010 | 09:52 AM
dynarider925
1st Gear
I'll check the tension, I think it will not deflect like you describe cornishman, it seemed a lot tighter when I pushed on it.
Old Aug 21, 2010 | 03:02 PM
cornishman's Avatar
cornishman
If the belt is too tight it will put stress on your gearbox....not good.....a little on the loose side is better than over tight......if you are not sure maybe get a second opinion.
Old Aug 21, 2010 | 03:11 PM
cornishman's Avatar
cornishman
If you do adjust or even if you don,t check that the wheel is correctly aligned. There is a small hole approx 3mm diameter drilled in the swingarm approx 75mm in front of the axle. The distance from the hole to the centre of the axle should be the same either side. Maybe use a bent piece of wire or an allen key as a measure.This will ensure the pulleys are aligned / belt pulling true. Hope this makes sense.
Old Aug 21, 2010 | 04:18 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
First wash the drive belt and pulley with soap and warm water. Check for deflection in the slot on the belt guard. Too tight or too loose or sometimes dirty will cause noise. Look at the edges of the belt for wear indicating rear wheel misalignment.
Old Aug 21, 2010 | 09:58 PM
Donny's Avatar
Donny
I found that if I adjust my belt to the specs in the manual, it ends up way too tight when it warms up. I also found that the alignment holes on my swingarm are off a little. If adjusted to those holes, my bike dog tracks and belt wears on the left side, and makes noise.
KelliCLE
May 19, 2017 08:43 PM
gilmour68
Jun 8, 2016 01:04 AM
Falcon195
Jul 11, 2012 07:26 PM
94 Heritage
Aug 8, 2008 10:04 AM
94 Heritage
May 15, 2007 09:24 AM
