air shocks
Old Aug 24, 2010 | 05:48 PM
712jared's Avatar
712jared
Default air shocks
hi was thinking of putting some air shocks off a touring bike on my 03 fxd superglider any one know witch ones will fit?
Old Aug 24, 2010 | 05:52 PM
p51bombay's Avatar
p51bombay
Pretty much all fit - 09 up versions can use higher pressure. These are 54565-09
$71 on ebay - brand new take off's
12.75" OAL
Old Aug 24, 2010 | 05:55 PM
JRK5892's Avatar
JRK5892
Rear air shocks for Dyna:
https://www.hdforums.com/m_1972403/tm.htm
https://www.hdforums.com/m_2445877/tm.htm
https://www.hdforums.com/m_2372126/tm.htm
https://www.hdforums.com/m_3388111/m...tm.htm#3689316
https://www.hdforums.com/m_3577130/tm.htm
Recommended air pressures
0-10 lbs for a 150-lb to 200-lb rider.
5-15 lbs for a 200-lb to 250-lb rider.
20-25 lbs for a rider with passenger.
FL air preload rear suspension range is 0-35 lbs of pressure.
FLHRS and FLXH low-profile shocks are 0-50 lbs max.
Old Aug 24, 2010 | 05:58 PM
p51bombay's Avatar
p51bombay
Forgot a photo
Old Aug 24, 2010 | 06:05 PM
WS6 Formula's Avatar
WS6 Formula
Some info below:
Originally Posted by WS6 Formula
I did the same but used the shorter Street Glide shocks. Much smoother ride, really takes out the road chop. I use a air compressor with a regulator set at 40 psi to fill them, then use a pressure gauge with a bleed off valve and bleed them down to 10 psi. Only modification to make them fit is to trim the rubber boot where it attaches to the shock so that it doesn't interfere with the belt guard, might be better just to shim the shocks out about a 1/4".
More info here: https://www.hdforums.com/forum/showt...eferrerid=9012
Old Aug 24, 2010 | 06:10 PM
p51bombay's Avatar
p51bombay
That's weird - no clearance issues on mine, bolted right on.
Old Aug 24, 2010 | 10:03 PM
WS6 Formula
The rubber boot comes in contact with the belt guard, but you can trim the top of the boot even with the shock housing, like in below photo.
More information on the air shocks here: https://www.hdforums.com/m_2372126/tm.htm
manzo
2014-2024 Touring Models
Mar 18, 2014 07:08 PM
dgdamore
Jun 29, 2011 03:31 PM
makstv5
Apr 6, 2010 06:49 AM
gmc1999
Nov 26, 2008 11:37 AM
Thunderchild
Mar 17, 2008 10:52 AM
