Just got dyno tuned
Old Sep 25, 2010 | 07:44 PM
hdFLH68's Avatar
hdFLH68
Default Just got dyno tuned
Up upgraded to a Wood TW-6G cam 2 weeks ago. Went to the dyno the first time and had a rear injector quit and one of my pushrods backed off. Luckily I trailered it to the dyno. Got that all fixed and drove the bike an hour back to the dyno today. Keeping in mind that I am at 7000ft elevation, the bike made 80hp/80tq. It has V&H Pythons duals and K&N filter. Worlds of difference on the poser and performance. I know my gas mileage will suffer cause it's much more fun to drive now
Next summer I do the top end to finish the 98" conversion. I could only afford the cams for now. Glad I didn't wait until I could afford it all
Old Sep 25, 2010 | 09:30 PM
Kaycee's Avatar
Kaycee
hmmmm Thats all u did was just the cams did u do the pushrods?I have been weighing this pretty heavy for my winter mod.If u don't mind me asking what did it cost to do this little upgrade?
Old Sep 25, 2010 | 10:13 PM
mentor70's Avatar
mentor70
prepare for a BIG jump in power with the 98 kit!
im running 10.2 comp. in Los Angeles, but I have a 11.0 to 1 kit ready if i ever hit the highlands again!
Old Sep 26, 2010 | 11:57 AM
hdFLH68's Avatar
hdFLH68
I got the kit from Scott at Hillside. I got the gear driven cams, cam gears,new inner bearings, bearings for the cam plate, outer timing gears plus a 4* advance key, S&S adjustable pushrod kit and gaskets. I think it was around $1100 with tax and shipping. I went with the adjustable one because I did not want to tear the whole top end apart just yet.
I bought the bearing puller and installer from Georges garage just because I wanted to be able to do it all myself and not take it to the dealer. Those were about $160.
The only thing I had to farm out was getting the cam bearings and cams pressed into the plate with the gears lined up. One of the service techs from local HD shop charged me $20 to do it..took maybe 10 minutes.
Having NEVER been inside a twin cam motor, if I were to do it again and had everything here, 3-4 hours. Take your time, get a service manual if you don't have one.
I called and talked to Vic (Sc-longhair) several times just for reassurance since he had done this not long ago
hdFLH68's Avatar
hdFLH68
I know. Hillsides 98" claims 110hp/110tq. I have to wait for next fall for that though
Old Sep 26, 2010 | 02:24 PM
SC-Longhair's Avatar
SC-Longhair
It's a little more involved for pre-06 bikes since you guys have bearings in the camplate.
I did cams on my '07 and all in all I had about $500-600 invested including cams and dyno tune. I reused stock pushrods. Going to gear drive does increase cost as well but some say with gear drive you don't lose power but gain a little extra because of the positive interaction of the gears that have zero play vs chain that can stretch and cause slight power loss.
Congrats, Bryan.
Old Sep 26, 2010 | 10:19 PM
wideglidebob's Avatar
wideglidebob
i have a 05 wide myself just did the 95 build i did the woods cam tw6, also did se flat pistons change to adj se pushrods new tappets, and the upgrade wil pump and plate, also had comp releases pushing 10.2 comp, two dynos both came back 95 hp and 98 torque, what a difference gas mileage sugs but well worth it
cike
Nov 18, 2013 11:27 AM
USMAMule
Exhaust System Topics
Dec 2, 2011 03:29 AM
KYFATBOB
Mar 19, 2011 09:53 PM
jurgie
Mar 1, 2010 09:35 AM
Road Ranger
Jan 23, 2010 11:46 AM
