lower forks powder coating. question??
Old Dec 20, 2010 | 02:28 PM
mitch573's Avatar
mitch573
2nd Gear
Default lower forks powder coating. question??
hey guys, i have a pile of stuff im gettin powder coated and i wanna do the lower fork legs, my question is, is how do i seprate the lowers from the sliders? is it the big allen key on the bottom of the fork, that seprates them??
thanks
Old Dec 20, 2010 | 02:32 PM
JRK5892's Avatar
JRK5892
you hvae to pull the dust boots, inside there is a retaining clip, remove that, then (this is after you have drained your fluid) then break that allen loose, once that is out, just pull them apart
Old Dec 20, 2010 | 03:04 PM
mitch573's Avatar
mitch573
2nd Gear
thanks buddy, i actually jus thought about askin you, you know your sht when it comes to powder. haha
Old Dec 20, 2010 | 03:34 PM
JRK5892's Avatar
JRK5892
ha ha ha no problem let me know if you have any questions. when you refill go with 15w oild! much nicer
Old Dec 20, 2010 | 04:51 PM
AFSSGT's Avatar
AFSSGT
Might be a dumb question, but how do you drain the fluid?
Old Dec 20, 2010 | 05:10 PM
JRK5892's Avatar
JRK5892
I break the top cap loose while they are still in the trees... once it is loose, then put a rag over the cap and un screw... remember it is pre loaded so it will want to FLY out, (alwasy cover your tank. after you have the cap off, slide out the fork leg, and dump it out, inside a spring, spacer, and washer will be in there, just look at the order it comes out and take note of the coils on the spring cause they hve to go back in that order and direction... when you dump it out pump the leg a few times to get it all out... done... thereis also a drain on the lower leg but it takes FOREVER
Old Dec 20, 2010 | 05:12 PM
spaceblue's Avatar
spaceblue
Nope it's not dumb. There is no drain on the 49mm forks and the large lower bolt is considered the drain. I just disassembled mine over a 5 gallon bucket and let the stuff run out into it.
Old Dec 20, 2010 | 05:31 PM
AFSSGT's Avatar
AFSSGT
Thanks!
Schmidt0221
Jun 18, 2017 10:43 PM
CryingJoker
Nov 13, 2016 07:26 AM
littled62
Oct 2, 2014 04:26 PM
WhiskeyHarley
May 16, 2013 12:19 PM
FLHT
Apr 1, 2008 10:31 AM
