New 10" Bars
Old Jan 1, 2011 | 05:17 PM
jims79flh's Avatar
jims79flh
Default New 10" Bars
I am having alot of trouble trying to fish in my switch wiring into my new Wild One 10" Drag Bars with strait risers. I got a fish wire in but can't get the wiring to make the bend down the risers. I have tried dish soap.
Old Jan 1, 2011 | 06:34 PM
biketroll's Avatar
biketroll
try pulling wires through the bar first then down through the riser, would have to unbolted this way.
Old Jan 1, 2011 | 07:08 PM
MacBean's Avatar
MacBean
you have to make a long taper. keep the pull cord tight so it will make the turn and not pass it.
Old Jan 1, 2011 | 08:34 PM
8541hog's Avatar
8541hog
Do you have them all bundled or individual? Much easier with individual conductors, use a push pull method.
Old Jan 1, 2011 | 08:50 PM
lhcstreetbob's Avatar
lhcstreetbob
I used a shop vac to suck the wires thru worked great...
Old Jan 1, 2011 | 08:52 PM
jims79flh's Avatar
jims79flh
I am installing T-Bars with welded on risers.
I will try the long taper in the morning, if anyone else has a idea please post.
Thanks
Old Jan 1, 2011 | 09:57 PM
PsTaN's Avatar
PsTaN
I used weedeater line .... ran that through the bars first. I then tied a knot in the line and offset that back past the connectors and wrapped it all up in electrical tape. The knot wouldnt let the the line slip out, but kept the bundle tight enough to easily pull through. I used air tool oil as well.
PsTaN
Old Jan 1, 2011 | 10:08 PM
8541hog's Avatar
8541hog
By individual conductors I meant all taped together at the head, but not taped the length of them in the bars, and yes the end must have a taper to it. If you gently pull as you push the other end they will guide through, having them as a loose bundle allows them to adjust, if you have them all taped together in the pipe it is very difficult if not impossible to make the turn.
Old Jan 1, 2011 | 10:51 PM
07BlueScoot's Avatar
07BlueScoot
Very well put, I have nothing to add just wanting to say my drag bars with welded on risers were waaaayyyy harder to wire than other bars (apes, mini apes, etc.) All I can say is it took a while and a hell of alot of persistance to get it done. Good luck man, sounds like your on the right track....
brian.macartney88@gmail.com
Feb 26, 2016 04:49 PM
StlJimmy
Jan 23, 2016 04:18 PM
Juggerpops
Sep 6, 2014 09:13 AM
imboden
Jun 8, 2007 03:47 PM
