FXDL shock adjustment
Old Mar 9, 2011 | 06:19 PM
Russa's Avatar
Russa
6th Gear
Default FXDL shock adjustment
Is there a way to adjust the spring preload with out buying the spaner wrench from HD?
Thanks
Old Mar 9, 2011 | 06:22 PM
ZeroFiveFour's Avatar
ZeroFiveFour
Some folks say you can use a rubber oil filter wrench. Some folks say two screwdrivers inserted into opposite sides of the shock will do it too.
Some say they can do it with their hands too. Worth a try.
I would drop the 10 bucks to avoid any inadvertent scratches you might get from a flying screwdriver or oil wrench.
Good luck.
Cheers,
Tom
Old Mar 9, 2011 | 06:36 PM
Russa's Avatar
Russa
6th Gear
Default preload adjustment
Thanks, I will try buy hand first. If it is only $10 I might just get it.
Old Mar 9, 2011 | 06:56 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Could be cheaper at an indy shop or thru a catalog.
Old Mar 9, 2011 | 07:15 PM
ZeroFiveFour
If you go with the wrench I would suggest putting a thin towel over the teeth of the wrench to minimize any chance of scratching your shock caps. That's what I do.
Cheers,
Tom
Old Mar 9, 2011 | 07:47 PM
SuperFastGlide's Avatar
SuperFastGlide
turned mine by hand, easier than i thought it would be.... if you cant get a good grip put on some rubber dish washing gloves
Old Mar 9, 2011 | 11:15 PM
goblin127's Avatar
goblin127
I do mine with leather gloves on. Some how I would have scratched them by now.
Old Mar 10, 2011 | 05:21 AM
Russa's Avatar
Russa
6th Gear
Can"t hurt to try the glove trick.
Old Mar 11, 2011 | 03:57 PM
dagored11's Avatar
dagored11
Default No Wrench Needed
Rubber gloves and a little *** power
Old Mar 11, 2011 | 04:09 PM
JRK5892's Avatar
JRK5892
i do it with the power of my mind... just stare at it for a few min and focus on what setting you watn
