Deltran Battery Tender Plus Question
Old Mar 21, 2011 | 03:36 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by rdondes
I just bought the Radio Shack $19.95 USD digital multimeter. Now I can check the battery charge level at rest, at startup and at idle.
But, how do I check the output of my Deltran Battery Tender Plus? If the Deltran is hooked up to the battery via the clamps on the posts, I get 14.7V if I touch the multimeter leads to the battery terminals or the Deltran's clamps. If I take the Deltran's clamps off of the battery posts, I get no reading at all from the multimeter.
Ran a test on my Deltran.
Apparently it is hard to measure the output on the Deltran because it is "computerized".
When I measured the Deltran output with my multimeter using DC 20 volts settings, the meter showed 0.015 volts output. This is caused by the Deltran settings: the lower the battery voltage, the higher the Deltran output is. This results in a decreasing Deltran output in volts when the battery gets charged. That's why the amber light turns to green once the battery has reached a voltage level of ~ 13,2 volts.
A non-computerized battery loader gives 13.2 volts power. When connected to a low voltage battery you will notice a high current of about 4-5 amps, which will decrease during battery loading time.
Old Mar 21, 2011 | 04:21 PM
Faast Ed's Avatar
Faast Ed
Try the same test with the Deltran unplugged from the wall outlet. Do you still get 14.7?
Old Mar 22, 2011 | 10:45 AM
rdondes's Avatar
rdondes
The output from the Deltran Battery Tender Plus cannot be measured. The Battery Tender will not put out anything unless hooked up to a battery. And if hooked up to a battery and plugged in, touching a multimeter's leads to the Battery Tender's clamps will only show the voltage of the motorcycle battery (same thing for touching the multimeter's leads to the Battery Tender's clamps if unplugged and the clamps are on the battery). So there really is no way to verify voltage or amperage coming out of the Battery Tender Plus.
I received the following email from Deltran Customer Service this morning in response to my question of can I measure the output of a Deltran Battery Tender Plus:
************ Email from Deltran Customer Support **************
RE: Contact Form
Subject : RE: Contact Form
To : RDondes@comcast.net
Tue Mar 22 2011 11:09:21 AM
The charger will not put out any voltage unless the charger is attached to a battery and the battery has to reach 14.9 volts before the unit will go to the float or maintenance mode. Thank you!
Pamela Carter
Deltran, Corp.
386-736-7900 X-236
386-873-4871 - Direct Line
******* End of Email from Deltran Customer Support ********
Apparently there must have been a "looseness" in my Battery Tender harness that has one end attached to my battery terminals and the other end (with the round connectors) secured to my tank console. I squeezed the round connectors a little and the Battery Tender Plus went from solid red, to solid red and blinking green. The solid red and blinking green lasted about 5 hours. This morning the Battery Tender Plus showed only solid green indicating a full charge. I checked the battery with my multimeter and it showed 13.9 volts. It appears that there is nothing wrong with either my battery or my Deltran Battery Tender Plus.
Richard
Old Mar 22, 2011 | 10:49 AM
lo-rider's Avatar
lo-rider
That's what I figured...a bad connection. Those miserable "trailer" connectors on this brand are the cheapest crap they could find.
Old Mar 22, 2011 | 11:42 AM
Morris9982's Avatar
Morris9982
I'm glad you figured it out.
Old Mar 22, 2011 | 04:59 PM
Faast Ed's Avatar
Faast Ed
That's why I said "unplugged from the wall outlet".
(Meaning "still hooked to the battery".)
Measure two times (both while hooked to the battery).
Once plugged into the wall outlet, and again unplugged from the wall outlet.
Should be a slight difference if that sucker is working.
BTW: Glad you found the issue.
ElectraJim
Jul 12, 2018 02:43 PM
zyban
Sep 16, 2016 11:09 PM
Harleydawgz
Jun 27, 2013 02:18 PM
WNMORE
Nov 8, 2011 10:36 AM
nutmagnet
Jul 7, 2008 07:23 PM
