jet help
Old Apr 15, 2011 | 10:54 AM
clowe's Avatar
clowe
Default jet help
Was wondering if anyone could give some advice. I have a 00 FXDX and running v&h short shots with no baffels and a arlen ness big sucker intake. Bike runs fine but has a small cough every now and then. Did not change any jets but I know that they need to be. Anyone running close to the same that can advise on what size jets would be best?
Old Apr 15, 2011 | 12:50 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Old Apr 15, 2011 | 01:28 PM
bklynbob's Avatar
bklynbob
46 slow,185 or 190 main .don't forget to adjust the mixture screw.If you wnt to run better under 3500rpm,get a pair of Khromewerks drag pipe baffles.will still be loud,but will run much better.
Old Apr 15, 2011 | 03:17 PM
jaxdwg's Avatar
jaxdwg
Put two #4 washers under the needle and it should take care of the little cough that is caused by a real lean spot in the needle. moving the needle up lets a bit more fuel in when at light throttle conditions which is where the coughing was happening in my experience with an 02. Worked good for me.
Old Apr 15, 2011 | 11:05 PM
goblin127's Avatar
goblin127
Good article in american iron mag this month all about weather to rejet or not.
Old Apr 16, 2011 | 07:44 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 on the article in the American Iron Magazine. IMHO Joe Minton has his all in one sock, good info from him, I trust him. That's the May issue.
Old Apr 16, 2011 | 08:18 PM
dynhd1's Avatar
dynhd1
Call V&H they will give you the correct jet numbers based on your info.
Old Aug 8, 2011 | 10:39 PM
harley hoggin 220's Avatar
harley hoggin 220
Stage I
I have a question i have a 1998 fxdl with a big sucker intake and a thunder header im gonna be installing a ev27 cam. What jetting should i use? Any help would be appreciated
Tonyparson1
Carburetor Related
May 25, 2017 06:16 AM
cobra2411
EVO
Apr 1, 2012 06:37 PM
Tompop
Exhaust System Topics
Jul 2, 2008 05:30 PM
20LowRider02
May 6, 2008 10:57 AM
ccondon23
Jul 28, 2007 08:45 PM
