Sheared Off Rear Pulley Bolts
The stock bolts, unless they were changed after 05 by the MoCo, are Grade 5, this info is available in the parts manual.
The bolts that are meant to be in there need to have the shoulder down inside the wheel so that the initial contact with the wheel is not at the threads, this is why the wheels are counter bored, it gives it added strength at the critical point. That is why you should not use bolts that are threaded all the way.
If you change your spacer it affects this fit, and may either not allow them to fully seat properly and tighten, or may not allow the shoulder to rest in the counter bore.
Many aftermarket pulley and bolt kits that I have seen include the wrong bolts, too short and/or threaded all the way. This was what the indy that I used installed on mine and they did not hold.
While I cannot say for sure, I think the chroming process weakens these bolts, which is why I will not use chromed bolts in this application. This may also be why formike56 only had 2 out of 12 pass the grade test he conducted.
As I said I was not positive about that, but in order for something to be chrome plated, does it not have to be slightly smaller to begin with, so it ends up the correct size? Just wondering.
Once I was home I pulled each bolt on at a time, applied some locktite, torqued them to spec, and marked each bolt. They have not budged in almost a year.
Need to separate pre '06 from '06 up too.
you can see it was a sheer
tools for the sleeve
done
