Converting 06 WG to 2010-2011 WG
Old May 20, 2011 | 02:28 AM
Frank ZX's Avatar
Frank ZX
Default Converting 06 WG to 2010-2011 WG
I can't believe no one has done this yet? From all the research I have done the 2006 thru 2011 Wide Glides most parts interchange. I recently bought a 2006 Wide Glide with only 3000 miles so it's barely broken in and I got it at a good price but I love the look of the 2010-2011 Wide Glides. My plans are to sell or swap the 06 fender,tail light,seat,sissy bar,mini ape handle bars,windshield,etc.and convert my 06 to look more like a 2010.
I was wondering if anyone else has done this or even thought about it?
Pros Vs Cons?
Old May 20, 2011 | 06:07 AM
Airborne350G's Avatar
Airborne350G
The rear fender will not fit without modifiying the supports. The rear fender is wider on the '10-'11 models.
Old May 20, 2011 | 07:29 AM
Warrior Redleg's Avatar
Warrior Redleg
+1 on that, however i think Harley makes a chopped fender kit you can get that would fit.....
Old May 20, 2011 | 07:33 AM
8541hog's Avatar
8541hog
You could probably get a 06-08 Street Bob fender and chop it to resemble the newer Wide Glide.
You could get a 10-11 WG tank and console and swap them, then it is mostly the bars and you would nearly have a clone.
Old May 20, 2011 | 10:11 PM
Frank ZX's Avatar
Frank ZX
How much wider? I am a aircraft mechanic and I do alot of sheet metal repairs so I feel comfortable adjusting the rear frame to fit the fender if need be.
Does anyone have a damaged 2010 rear fender they want to part with, or can someone give me the measurments?
Thanks
Old May 21, 2011 | 06:26 AM
8541hog's Avatar
8541hog
To make it fit you would have to chop off the struts and re-weld them, it would be much easier to mod the fender than the struts. If you ride 2up much I would not mod the struts, they support all the passenger weight.
Old May 21, 2011 | 07:39 AM
Airborne350G
Some one posted that thus ground down the fender mounts on the struts to make enough room to make the fender fit.
Old May 21, 2011 | 09:31 AM
SouthpawHD's Avatar
SouthpawHD
That's a really good idea! Keep us posted as to your progress. And remember, without pics, it doesn't exist.
tcarson84
Feb 18, 2016 05:04 PM
jeffbetrollin
Oct 1, 2015 02:46 PM
ddvr29
Mar 28, 2012 01:23 AM
DougM
Sep 24, 2008 08:32 PM
kuleli
May 30, 2008 12:57 PM
