Dyna Questions Link
Old Aug 29, 2009 | 12:29 PM
Lorance66's Avatar
Lorance66
Default Dyna Questions Link
Someone posted a LONG list of links and I had it bookmarked but I seem to have lost it. The links were all about whats the best stuff. It was links to all kinds of threads relating to that sort of thing.
I simply have a question about seats but since the "search function *****" will attack just about anyone I want to go reading first. The search does not always work it seems, as I cannot find the one post I am looking for.
Anyone know the post I am talking about and do you have the link?
thanks
Brad
Old Aug 29, 2009 | 12:39 PM
Lorance66's Avatar
Lorance66
Nevermind.....found it, or at least a modified version. I think this is the original one with more added. This one posted by Joe (JRK)
https://www.hdforums.com/forum/dyna-...t-threads.html
Old Aug 29, 2009 | 12:42 PM
Axman's Avatar
Axman
This?
https://www.hdforums.com/forum/dyna-...-dyna-faq.html
Old Aug 29, 2009 | 12:49 PM
JRK5892's Avatar
JRK5892
here is the one i have been saving up and using
How Forum links
How to post pic
https://www.hdforums.com/forum/forum-issues/286445-how-to-add-pictures-to-a-post.html
CLEANING YOUR IDLE AIR CONTROLLER (IAC)
https://www.hdforums.com/forum/dyna-...g-at-idle.html
Fork oil change
https://www.hdforums.com/forum/dyna-...-fork-oil.html
V&H Big radious 2-2 baffle removal
https://www.hdforums.com/forum/dyna-...onsters-2.html
Progressive drop in lowering kit
https://www.hdforums.com/forum/dyna-...op-in-kit.html
mounting a nightrod fairing on Dyna
https://www.hdforums.com/forum/dyna-...-09-dynas.html
steering Head Adjustment
https://www.hdforums.com/forum/dyna-...djustment.html
Dyna Battery
https://www.hdforums.com/forum/dyna-...batteries.html
Front motor mount dyna
https://www.hdforums.com/forum/dyna-...or-mounts.html
https://www.hdforums.com/forum/dyna-...tor-mount.html
Painting you bike
https://www.hdforums.com/forum/dyna-...nt-set-up.html
Engine tools to get cheap
http://www.georges-garage.com/
dyna suspension upgrade
https://www.hdforums.com/forum/dyna-...uspension.html
Foot clutch Jockey shift
https://www.hdforums.com/forum/sport...e-shifter.html
Shifter shaft seal replacement
https://www.hdforums.com/forum/dyna-...haft-seal.html
Bushing how to
https://www.hdforums.com/forum/dyna-glide-models/263272-riser-bushing-how-to.html
making your own lollypops
https://www.hdforums.com/forum/sport...p-baffles.html
making your own baffles
https://www.hdforums.com/forum/dyna-...ight-five.html
Bottle opener how to
https://www.hdforums.com/forum/dyna-glide-models/263277-how-to-beer-bottle-opener.html
Stock muffler mod
https://www.hdforums.com/forum/dyna-...ler-mod-2.html
Duel disk brakes:
https://www.hdforums.com/m_3632699/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/266574-dual-brakes-on-street-bob-fast-straight-no-fade.html
https://www.hdforums.com/forum/dyna-...will-they.html
https://www.hdforums.com/forum/dyna-...kit-today.html
4 piston brembo brakes (off sport bike)
https://www.hdforums.com/forum/dyna-...al-brembo.html
Cams:
https://www.hdforums.com/m_3634982/tm.htm
https://www.hdforums.com/m_2066227/tm.htm
https://www.hdforums.com/m_2318998/tm.htm
https://www.hdforums.com/m_3624153/tm.htm
https://www.hdforums.com/m_3584042/tm.htm
https://www.hdforums.com/m_3574448/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/274967-cam-and-air-cleaner-thoughts.html
https://www.hdforums.com/forum/dyna-glide-models/283821-not-sure-if-this-video-has-been-posted-before-but-i-found-it-interesting.html
http://www.youtube.com/watch?v=MPRbpbGq0-k
https://www.hdforums.com/forum/dyna-...stalled-3.html
https://www.hdforums.com/forum/dyna-...head-work.html
https://www.hdforums.com/forum/dyna-...-7-cams-2.html
Cams for 06
https://www.hdforums.com/forum/dyna-...my-06-bob.html
Engine Upgrade:
https://www.hdforums.com/forum/dyna-...-bore-kit.html
Front end removal:
https://www.hdforums.com/forum/dyna-glide-models/291392-front-end-removal-advice.html
Floor boards:
https://www.hdforums.com/m_3358319/mpage_1/key_/tm.htm
Epoxy paint
https://www.hdforums.com/forum/dyna-...y-paint-3.html
Extra Lighting:
https://www.hdforums.com/m_3549132/tm.htm
Best solo seat:
http://www.HDForums.com/m_2971212/tm.htm
http://www.HDForums.com/m_1743730/tm.htm
http://www.HDForums.com/m_1531544/tm.htm
checking spokes
https://www.hdforums.com/forum/dyna-glide-models/270271-how-to-check-wheel-spokes.html
EFI Recalibration
http://www.harley-davidson-forum.net...ead.php?t=7227
Fork boots/gaiters:
http://www.HDForums.com/m_2907787/tm.htm
http://www.HDForums.com/m_1002152/tm.htm
https://www.hdforums.com/forum/dyna-...ork-boots.html
Fork oil change
https://www.hdforums.com/forum/dyna-glide-models/277701-fork-oil-change-out-help.html
fork oil suspension upgrade isolator
https://www.hdforums.com/forum/dyna-...upgrade-3.html
Fork seal and lower leg disassembly
https://www.hdforums.com/forum/dyna-...fork-tube.html
fork seals:
https://www.hdforums.com/forum/dyna-...-question.html
Floor boards on dyna
https://www.hdforums.com/forum/dyna-glide-models/271723-fxdp-floorboards-on-06-later-dyna.html
https://www.hdforums.com/forum/dyna-...ater-dyna.html
LED’S: (pics)
https://www.hdforums.com/forum/softail-models/271952-light-me-up.html
Stem nut washer replacement
https://www.hdforums.com/forum/showt...87#post3795587
Fall away test
https://www.hdforums.com/forum/dyna-glide-models/272983-fall-away-test.html
fall away adjustment
https://www.hdforums.com/forum/dyna-...way-check.html
Scratch removal
https://www.hdforums.com/forum/dyna-glide-models/274991-vivid-black.html
Suspension/Shock mods/lowering:
http://www.HDForums.com/m_986458/tm.htm
http://www.HDForums.com/m_1802894/tm.htm
http://www.HDForums.com/m_2252964/tm.htm
http://www.HDForums.com/m_1822088/tm.htm
Drop in front lowering kit
https://www.hdforums.com/forum/dyna-...ed-pics-3.html
Fork oil change
https://www.hdforums.com/forum/dyna-...-easy-way.html
Tire locations to buy:
https://www.hdforums.com/forum/showt...45#post3792345
https://www.hdforums.com/forum/dyna-...or-a-tire.html
Tach install:
https://www.hdforums.com/m_3626374/tm.htm
http://www.shareaproject.com/pages/i...i,2354,00.html
https://www.hdforums.com/m_2877668/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/266756-mini-tach-installed-on-fxdci.html
https://www.hdforums.com/m_2750573/tm.htm
https://www.hdforums.com/forum/dyna-...g-ideas-2.html
Low rider dash tach install w/ idiot lights
Deuce Wheel:
https://www.hdforums.com/m_813473/tm.htm
https://www.hdforums.com/m_958300/tm.htm
https://www.hdforums.com/m_863737/tm.htm
https://www.hdforums.com/m_833970/tm.htm
Do-Rag Guidance
https://www.hdforums.com/m_1944738/tm.htm
Dyna vibration:
https://www.hdforums.com/m_1005462/tm.htm
https://www.hdforums.com/m_3496437/tm.htm
Exhaust Pictures:
https://www.hdforums.com/m_797869/tm.htm
Exhaust gasket replacement
https://www.hdforums.com/forum/dyna-glide-models/264206-exhaust-gasket-questions.html
Forward controls install:
https://www.hdforums.com/m_2339042/tm.htm
https://www.hdforums.com/m_613252/tm.htm
https://www.hdforums.com/m_576946/tm.htm
Fuel Management(SERT, PC-III, Thundermax, ect.):
http://www.nightrider.com/biketech/m...i_upgrades.htm
https://www.hdforums.com/m_2763702/tm.htm \\;- Trotter Thread
https://www.hdforums.com/m_1420193/tm.htm \\;- PhilM - DTT
https://www.hdforums.com/m_180308/tm.htm \\;- Poll
https://www.hdforums.com/m_2564296/tm.htm
https://www.hdforums.com/m_1723575/tm.htm
https://www.hdforums.com/m_1597567/tm.htm
https://www.hdforums.com/m_980076/tm.htm
https://www.hdforums.com/m_2792381/tm.htm
Garage door opener
http://www.shareaproject.com/pages/p...,p,208,00.html
https://www.hdforums.com/forum/showt...=127027&page=3
GPS
https://www.hdforums.com/forum/showt...=266073&page=2
https://www.hdforums.com/forum/sportster-models/263038-gps-on-sportster-pics.html
Inner primary bearing:
https://www.hdforums.com/m_3609254/tm.htm
https://www.hdforums.com/m_1781139/tm.htm
https://www.hdforums.com/m_2540619/tm.htm
https://www.hdforums.com/m_2269574/tm.htm
https://www.hdforums.com/m_1696586/tm.htm
https://www.hdforums.com/forum/dyna-...and-cause.html
good news:
https://www.hdforums.com/forum/dyna-...y-bearing.html
Little hole in front fender:
https://www.hdforums.com/m_2395589/tm.htm
https://www.hdforums.com/m_1960563/tm.htm
Holes in rear fender:
https://www.hdforums.com/m_2750651/tm.htm
Seat scratching from passenger seat
https://www.hdforums.com/forum/dyna-glide-models/266024-prevent-seat-scratching.html
Seat pictures:
https://www.hdforums.com/m_798151/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/270877-le-pera-silhouette-or-bare-bones.html
Shorter kick stand
https://www.hdforums.com/m_2546488/m...tm.htm#3270218
Rear air shocks for Dyna:
https://www.hdforums.com/m_1972403/tm.htm
https://www.hdforums.com/m_2445877/tm.htm
https://www.hdforums.com/m_2372126/tm.htm
https://www.hdforums.com/m_3388111/m...tm.htm#3689316
https://www.hdforums.com/m_3577130/tm.htm
Recommended air pressures
0-10 lbs for a 150-lb to 200-lb rider.
5-15 lbs for a 200-lb to 250-lb rider.
20-25 lbs for a rider with passenger.
FL air preload rear suspension range is 0-35 lbs of pressure.
FLHRS and FLXH low-profile shocks are 0-50 lbs max.
Phone numbers for shocks
https://www.hdforums.com/forum/showt...=266506&page=2
Removing reflectors:
https://www.hdforums.com/m_2863606/tm.htm
https://www.hdforums.com/m_2050477/tm.htm
https://www.hdforums.com/m_2579621/tm.htm
https://www.hdforums.com/m_1744279/tm.htm
Rotor/Stator:
https://www.hdforums.com/m_1889748/tm.htm
https://www.hdforums.com/forum/dyna-...-a-stator.html
Superglide speedo relocation
https://www.hdforums.com/m_671689/tm.htm
21” wheel
https://www.hdforums.com/m_2698051/tm.htm
https://www.hdforums.com/m_1529029/tm.htm
https://www.hdforums.com/m_2790021/tm.htm
https://www.hdforums.com/m_1094755/tm.htm
https://www.hdforums.com/forum/dyna-...-rim-swap.html
Wiring extension for apes:
HD Wire Extension Kit 72137-03
http://www.designsbynovello.net/
https://www.hdforums.com/m_1328001/tm.htm - Step by Step
https://www.hdforums.com/m_1180682/tm.htm
https://www.hdforums.com/m_1839302/tm.htm
Installing APE’s
https://www.hdforums.com/forum/dyna-glide-models/88710-my-ape-install.html
https://www.hdforums.com/forum/showthread.php?t=88710
Internal wiring bars
https://www.hdforums.com/forum/dyna-glide-models/14129-evolved-to-the-apes-done-thanks-new-pics.html
https://www.hdforums.com/forum/dyna-glide-models/68079-how-to-do-handlebar-internal-wiring.html
https://www.hdforums.com/forum/dyna-...h-my-bars.html
ext: http://www.jpcycles.com/productgroup...9-9D98ED920065
What saddlebags without turn signal relocation:
https://www.hdforums.com/m_298019/tm.htm
https://www.hdforums.com/m_2298730/tm.htm
https://www.hdforums.com/m_1172037/tm.htm
Wide tire kit:
https://www.hdforums.com/m_3596624/tm.htm
https://www.hdforums.com/m_2952015/tm.htm
https://www.hdforums.com/m_2914836/tm.htm
https://www.hdforums.com/m_2642795/tm.htm
240+ tire kit
https://www.hdforums.com/forum/dyna-...-tire-kit.html
180 rear tire for street bob manufactures
https://www.hdforums.com/forum/dyna-...streetbob.html
https://www.hdforums.com/forum/dyna-...ed-w-pics.html
cheap place for 180 tire
https://www.hdforums.com/forum/dyna-...wide-tire.html
Windshield buffeting:
https://www.hdforums.com/m_2363828/tm.htm
https://www.hdforums.com/m_868000/tm.htm
Making your own side mount plate
https://www.hdforums.com/m_2284594/tm.htm
Touring bobs
https://www.hdforums.com/forum/dyna-glide-models/280256-touring-street-bobs.html
Floating rotors
https://www.hdforums.com/forum/dyna-glide-models/279425-brake-rotors.html
How to check diagnostic codes
https://www.hdforums.com/forum/dyna-glide-models/264270-check-engine-light.html
https://www.hdforums.com/m_2293229/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/139328-identify-trouble-codes-and-clear-them.html
https://www.hdforums.com/forum/dyna-...06-2008-a.html
Horn relocation
https://www.hdforums.com/m_1212381/m...tm.htm#3639126
Wire wrap & hot topper
https://www.hdforums.com/forum/dyna-glide-models/263432-cheap-wire-covers-and-hot-toppers.html
Engine mounts balancing
https://www.hdforums.com/forum/dyna-glide-models/264143-front-end-wobble-on-decel-any-suggestions.html
POLY Engine mounts
http://www.glide-pro.com/
https://www.hdforums.com/forum/dyna-...-mounts-3.html
Motorcycle lift:
https://www.hdforums.com/forum/showt...=1#post3732596
sporty speedo relocation
https://www.hdforums.com/forum/sportster-models/268537-speedo-relocating.html
Tank Dents
https://www.hdforums.com/forum/showt...25#post3769025
battery tender
https://www.hdforums.com/forum/dyna-glide-models/269116-want-a-cheap-battery-tender.html
Manuals
https://www.hdforums.com/forum/useless-threads/271162-few-good-links-for-you-guys.html
Wood bike stand
https://www.hdforums.com/forum/showt...95#post3790995
passanger seat protection (scratching)
https://www.hdforums.com/forum/showthread.php?t=266024
True-Track
https://www.hdforums.com/forum/dyna-...-track-13.html
https://www.hdforums.com/forum/dyna-...k-install.html
https://www.hdforums.com/forum/dyna-...ositrac-2.html
lacing wheels tips
https://www.hdforums.com/forum/dyna-...21-inch-2.html
“sickest” bob
https://www.hdforums.com/forum/dyna-glide-models/269155-who-has-the-sickest-bob.html
EFI to Carb conversion
https://www.hdforums.com/forum/dyna-glide-models/276269-efi-to-carb-conversion.html
Carb tuning
Keihin:
http://www.keihin-us.com/tune.htm
Mikuni:
http://www.mikuni.com/fs-carburetor.html
Wide Glide tree conversion on St bob
https://www.hdforums.com/forum/dyna-glide-models/280286-wide-glide-triple-trees-conversion-for-dyna-part-and-prices.html
Spark plug links
http://www.totalmotorcycle.com/maint...sparkplugs.htm
CLEANING/ Detail
http://ez33.com/Detailing.htm
Making your own baffles
http://www.motorcycle-journal.com/fo...ow-merged.html
TIN’s removal:
https://www.hdforums.com/forum/dyna-...n-removal.html
ICECAPS master list:
https://www.hdforums.com/forum/dyna-...ful-links.html
LOWERING FRONT SPRINGS
https://www.hdforums.com/forum/dyna-...front-end.html
https://www.hdforums.com/forum/dyna-...f-warning.html
POLISHING
https://www.hdforums.com/forum/sport...sliders-2.html
Clutch spring replacement
https://www.hdforums.com/forum/dyna-...ip-to-bob.html
front islolator
https://www.hdforums.com/forum/dyna-...-biltwell.html
That Part number: 47583-90B = Front isolators. Cost me $71 at Zanotti's with $14 for shipping. Not bad if you ask me! Got here in less then a week too. It seriously makes a HUGE difference man.
Fatboy wheel on street bob
https://www.hdforums.com/forum/dyna-...heel-info.html
Installing lower legs
https://www.hdforums.com/forum/dyna-...ork-lower.html
How to Epoxy paint fork lowers
https://www.hdforums.com/forum/dyna-...ower-legs.html
Lower kick stand
https://www.hdforums.com/forum/dyna-...step-pics.html
removing cam cover
https://www.hdforums.com/forum/dyna-...cam-cover.html
30t pully
https://www.hdforums.com/forum/dyna-...y-install.html
https://www.hdforums.com/forum/dyna-...-pictures.html
https://www.hdforums.com/forum/dyna-...results-2.html
order parts from:
http://www.axiomcycles.com/pages/ite...temsection=129
Pulley number - drag# 1201-0227
Cluch spring - drag# DS-199218
SE Clutch spring replacement
https://www.hdforums.com/forum/dyna-...questions.html
Stator:
https://www.hdforums.com/forum/dyna-...press-4-a.html
Old Aug 29, 2009 | 12:51 PM
Lorance66's Avatar
Lorance66
wow Joe...you've been busy adding links! That list is getting great
Old Aug 29, 2009 | 04:50 PM
Delmarksman's Avatar
Delmarksman
Wow! What a great list.
Bookmarking
Old Aug 29, 2009 | 04:54 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by Delmarksman
...Wow! What a great list....
Check out this one as well!! https://www.hdforums.com/kbase/
Old Feb 2, 2010 | 10:09 PM
scorchedearthpolicy's Avatar
scorchedearthpolicy
This a great list!
Old Feb 3, 2010 | 06:08 AM
Pa-Rider's Avatar
Pa-Rider
holy crap Joe, that's a he11 of a list..
Old Feb 3, 2010 | 06:56 AM
rlhdude's Avatar
rlhdude
Many many many thanks for this list. Now I do not need to bug you guys as much!
