Check Engine light on and Speedo backlight out intermittently
Old May 31, 2011 | 09:00 PM
mrfixit440's Avatar
mrfixit440
4th Gear
Default Check Engine light on and Speedo backlight out intermittently
I have a 2008 Dyna Super Glide. On Saturday, I noticed the Check Engine light was coming on intermittently and my sixth gear light wasn't coming on at all. Got to my destination and parked it until Monday. On Monday night going home, my speedometer backlight went out by the time I got into sixth gear. When I shifted down, it came back on. This didn't help me on the freeway. My DTC codes are p0563, b0563, b1006, b1007. I cleared them and sandpapered my battery connections. Just did a quick test drive down the freeway and haven't noticed any problems. No new DTC codes either. Hopefully, its fixed!
Old Jun 1, 2011 | 10:02 AM
JRK5892's Avatar
JRK5892
nice! hope they stay away!!!
Old Jun 1, 2011 | 10:40 AM
Maclugie's Avatar
Maclugie
These really are simple machines, aren't they?
Old Jun 1, 2011 | 05:10 PM
mrfixit440's Avatar
mrfixit440
4th Gear
Well, driving to work this morning, I got the same symptoms. From what I've been reading on here, I should check the battery voltage while its running, correct? Whats a good voltage range I should be looking for? Is there anything else I need to check? I guess the voltage regulator is suspect if I don't have a good volt reading, correct? Thanks for the help in advance.
Old Jun 1, 2011 | 09:22 PM
mrfixit440's Avatar
mrfixit440
4th Gear
bringing up to top
Old Aug 3, 2012 | 11:03 AM
1911NT's Avatar
1911NT
I'm having the same problems with my 08 Night Train, with the addition of when i pull the clutch in and let the bike coast the the engine will die.
I checked the battery terminals, and changed my voltage reg. no difference.
Any ideas or suggestions???
Thanks
Old Sep 4, 2012 | 11:51 PM
jms428's Avatar
jms428
Bump for same issues , backlight goes out and occasional check engine light, and no 6th gear light...
any info be helpful. thanks
Old Jan 21, 2015 | 12:43 PM
Shorty127's Avatar
Shorty127
1st Gear
Default Speedo backlight & indicator lights go out
I have a 2011 Deluxe, intermittent problem. Headlight brightens, then speedo speedo backlight goes out (if in 6,6 light goes out) dash indicator lights go out. Started doing it for just seconds but then staying out longer. Sometimes when these lights come back on the security light will light. Long story. I swapped voltage regulators with my 2013 Heritage. Now the Heritage is having all the same problems. So for me it is Voltage Regulator !!
Old Jan 21, 2015 | 03:07 PM
stupid_rope's Avatar
stupid_rope
just a bit of advice, check the date of the post before commenting on it. that way we're not dragging up posts from 3 years ago
astra
Sep 22, 2017 07:24 AM
cerati666
Aug 4, 2015 02:10 PM
jrdfatboy
Jul 30, 2012 06:33 AM
mrfixit440
Jun 2, 2011 08:44 PM
bad news
Aug 14, 2010 01:58 PM
