Changing Dyna Fat Bob Derby Cover Question
Old Jul 27, 2011 | 07:55 PM
armykappasig's Avatar
armykappasig
6th Gear
Originally Posted by mracer
I'm surprised that you managed to remove it without an impact driver- obviously the previous installer did not use "blue" loctite. Make sure you use locktite when you finish the job. Much more important than torque lbs. IMO
There is so much heat down there when the bikes running. wouldn't that more or less seal the loctite in there? I would think it would requite a large impact wrench to remove the derby cover then.. or am I wrong?
Old Jul 27, 2011 | 08:10 PM
PigInaBlanket's Avatar
PigInaBlanket
Did he thank you for not painting it pink before you put it on?
Old Jul 27, 2011 | 08:41 PM
studiopeg's Avatar
studiopeg
bwaa haaa haaa. I did ask if he would let me put two red crystals in Willie's eyes. He said NO!
Old Jul 28, 2011 | 07:40 AM
mracer's Avatar
mracer
Talking
You are right on the money! I am not a bike expert, but have spent my life in the racing industry so I feel blue loctite is a must on a bike due to vibration- An impact driver is probably standard equipment for most harley techs. Proper tools are much cheaper than replacing damaged fittings. Using an impact driver with the correct socket is actually easier than trying to force it with a torx screw driver or similar tool. You can purchase a small unit at most aftermarket tool suppliers for under 20 bucks.
Old Jul 28, 2011 | 08:30 AM
p51bombay's Avatar
p51bombay
Nowhere in the Dyna manual does it recommend this use of loctite on the derby cover, personally I think it will just set you up for stripping the screws - never used it on mine, never lost a screw and when removed they come off with a nice little crack - telling me they were tight because they were torqued to spec.
Old Jul 28, 2011 | 06:33 PM
mracer's Avatar
mracer
can't go wrong by following the manual--
gweissel
Mar 7, 2017 01:28 PM
brummet24
Oct 16, 2012 09:35 AM
wvguy
Dec 27, 2008 06:12 PM
durwood
Mar 27, 2008 08:41 AM
YellowHawk
Dec 28, 2007 01:33 PM
