??? bad fuel pac????
Old Aug 24, 2011 | 01:03 AM
riflecoach's Avatar
riflecoach
6th Gear
Default ??? bad fuel pac????
I bought a 2008 dyna my first Harley used. the bike ran rough at first, then i put on V&H naked air intake, I thought it was bet $125 i ever spent, but in two weeks the dyna is rough again, it feels like diesel tractor. all the smoothness was gone, tried a deferent gas the same problem.
*After the air cleaner went on the bike it feelt like new . 2 short weeks later crap alot of decel pop and feels a little hotter.
3900 miles V&H slip on pipes,fuelpac and V&H air intake.
Any ideas
Old Aug 24, 2011 | 01:28 AM
blink1968's Avatar
blink1968
try unhooking the fuelpak and putting stock a/c back on and see if that helps if that helps go online and get new set of numbers from vance and hines website and put it all back on ie... the a/c and fuelpak
Old Aug 24, 2011 | 04:44 AM
Foxster's Avatar
Foxster
There's a major flaw with the V&H Fuelpak that you have found for yourself: The O2 sensors are retained and the Fuelpak can't cope with this.
This means that some time after fitting, the ECU thinks that the bike is running rich because of the extra fuel that Fuelpak is causing and drags the fuel back down, over-riding the Fuelpak in all conditions except hard acceleration and high speed. It will take a while for the bike to adjust to this, as you have found.
Plus V&H slip-ons are a bit crap and have poor low/mid rev performance.
One quick and relatively cheap fix would be to fit some Xieds as well as the Fuelpak. This fools the ECU into thinking the bike is running leaner than it is and so won't be so likely to try to drag the AFR back down.
Its all a fudge of course. You are much better getting a proper fueling soution and some decent pipes.
Old Aug 24, 2011 | 06:39 AM
Slipstrm's Avatar
Slipstrm
V&H has the maps on their website, numbers were changed pretty dramatically a few months ago, make sure you have the latest map for your setup.
I love both my FuelPak's.
Old Aug 26, 2011 | 02:04 PM
riflecoach's Avatar
riflecoach
6th Gear
I called fuelpac and they gave me codes to shut it off but it is still rough any ideas. Thanks
Old Aug 26, 2011 | 03:29 PM
riflecoach's Avatar
riflecoach
6th Gear
Also I pulled the plugs and they on white. Any ideas what would make it run lean that fast?
Old Aug 26, 2011 | 03:55 PM
missedem's Avatar
missedem
If the problem is not your fuel pak you might have an exhaust leak between your slip ons and the head pipes . New exhaust clamps and some high temp silicone (orange if I believe memory serves) are always a good idea.
Old Aug 26, 2011 | 06:41 PM
riflecoach's Avatar
riflecoach
6th Gear
Been on the phone again with fuelpac and they said it could be an intake leak. Take off the naked and put back on.
Old Aug 26, 2011 | 06:43 PM
missedem's Avatar
missedem
Hope that cures your ills. intake and exhaust leaks are a pain in the butt.
Old Aug 26, 2011 | 09:17 PM
nevil's Avatar
nevil
First make sure you don't have any mechanical problems like leaks. Before you bother to take off the intake (unless you did it already) get some throttle body or carb cleaner and spray the intake flanges when hot. Do it from the right side and don't get any into the air intake. If there's a change in the idle you have a leak. If not, make sure when you reinstall the intake you torque it correctly.
Like missedem said, look for exhaust leaks too.
Are your plugs even leaner than before? They will be white with the stock setup, too.
austiny
Jul 7, 2010 09:18 PM
a21m
Apr 12, 2008 01:59 PM
RoyalTexan
Dec 11, 2007 12:45 PM
Axeman71
Sep 2, 2007 10:31 AM
spn98
Exhaust System Topics
Apr 25, 2007 12:18 PM
