ok heres a new guy question
Old Sep 22, 2011 | 10:04 PM
2011bob's Avatar
2011bob
Default ok heres a new guy question
ok i just finished installing a set of forward controls on my 2011 street bob. this is gonna be a dumb question....where do i add the fluid back in? i know it holds about 1qt. there is no hole in the chain drive cover to add fluid. once i figure that out i will be praying that i assembled everything correctly.
Old Sep 22, 2011 | 10:22 PM
Odis01's Avatar
Odis01
Owners manual says pour 1 qt in through the clutch inspection cover opening. I haven't done it though.
Jim
JaronB's Avatar
JaronB
1st off get a Factory Service manual because it has everything.
2nd you refill the primary by removing that round cover held in with a torx. Add your quart and put the cover back on.
On the pic below the silver round cover on the primary cover with the 5 torx bolts.
Old Sep 25, 2011 | 09:10 PM
2011bob's Avatar
2011bob
thanks got it. my question now is my clutch. before i put the forward controls on it released alot sooner then it does now after being in the chaincase area. now it releases when the lever is almost all the way out. can this be adjusted? did i screw something up while doing the install?
Old Sep 25, 2011 | 09:16 PM
SC-Longhair's Avatar
SC-Longhair
Yes you can adjust your clutch. it's very simple.
You need a 11/16 offset wrench and an allen wrench (don't remember which size).
If you search youtube, there is a very simple video posted by ExpertVillage.
http://www.youtube.com/watch?v=Qw6da27b1w4
Loosen your clutch cable completely at the adjuster.
Open your derby cover.
Loosen the large (11/16) locknut.
Tighten the adjuster screw (allen) until you see it start to engage the clutch. You'll see the plate in the center start to pull in.
Loosen that adjuster 1/2-1 turn back out.
Tighten locknut.
Adjust clutch cable.
Verify it all engages properly.
Reinstall the derby cover. Shouldn't take more than 15min to do.
Old Sep 25, 2011 | 09:58 PM
caaraa's Avatar
caaraa
Old Sep 26, 2011 | 01:46 AM
ynots's Avatar
ynots
aka Derby cover
Old Sep 26, 2011 | 06:25 AM
YeOldeStonecat's Avatar
YeOldeStonecat
Kinda like what was already clearly illustrated above?
Old Sep 26, 2011 | 10:28 AM
2011bob's Avatar
2011bob
thanks for the video. ill give that a shot. thanks for helpin out a new member.
Mikeduke108
Jun 15, 2014 06:46 AM
ralfareno
Oct 26, 2008 07:34 PM
boone432
Mar 24, 2007 07:18 PM
mastiff
Dec 13, 2006 12:15 AM
dert
Oil Archive (no new posts)
Sep 21, 2005 12:17 PM
