Tank Lift-from Jackyll, any words of advice before I install
Old Sep 27, 2011 | 10:15 PM
2XNightTrain's Avatar
2XNightTrain
Default Tank Lift-from Jackyll, any words of advice before I install
waiting....for your response
Old Sep 27, 2011 | 10:28 PM
neocontra's Avatar
neocontra
yeah...don't.
Old Sep 27, 2011 | 10:31 PM
dsiltman's Avatar
dsiltman
Take the tank dash off first and change the vent line and put the dash back on with the vent line just sticking out the front. Bolt the lift on then hook the vent line back up on the neck.
Old Sep 27, 2011 | 10:33 PM
2XNightTrain
Why? Let me know...
Old Sep 27, 2011 | 10:50 PM
dsiltman's Avatar
dsiltman
I have it on a street bob and it works fine, the only thing is it throws the fuel light off, it will come on sooner.
Old Sep 28, 2011 | 01:24 AM
Abbysam1's Avatar
Abbysam1
I installed the 2 inch lift last year and couldn't be happier. I had no problems with the install and I really like way it makes the bike look. The only issue, as mentioned, is that the fuel gauge shows empty sooner. I just keep track of the mileage.
Attached Thumbnails Tank Lift-from Jackyll, any words of advice before I install-photo.jpg
Old Sep 28, 2011 | 01:56 AM
XjldX's Avatar
XjldX
I have a 2" lift on my tank... I wasn't warned about the vent line. Found out the hard way when I ran out of line and had to take the dash off AFTER the line popped off and I wasn't paying attention to where it came from. Naturally I assumed it was a bigger deal than it was. So I just took the dash off, pulled a little slack in the vent line and put it all back together. Oh, one simple word of advice, don't install it with a full tank. It's easier to work with an empty tank and just in case you get a little over zealous and pull off your crossover, you won't have as much of a mess to clean up.
Old Sep 28, 2011 | 06:47 AM
DocDyna's Avatar
DocDyna
Default Cross-over line
Head others advice, get some venty line slack, and watch your cross-over. Mine with the 2" lift made my cross-over line a little tight around bottom of neck. I did not like that look or taughtness, so I replaced the line with a SS braided one about 2 inches longer. Also try to have a almost empty tank, just in case you have to fool with this line ( ask me how I know this....duh!).
I like the looks plus it gives more accessability to the top of the motor, for work and cleaning.
Old Sep 28, 2011 | 09:10 AM
perryross's Avatar
perryross
I’ve had a 2” Jackyll tank lift on an 07 SB and a 09NT.
Love the look it gave both of them.
http://s1125.photobucket.com/albums/...ent=07to09.jpg
I would suggest a longer crossover line as the stock
one will start to ware eventually if it’s to tight, mine did.
Sketchy
General Topics/Tech Tips
Jun 6, 2018 08:55 AM
The Dean
Apr 25, 2011 06:57 AM
gartec81
May 15, 2010 08:42 AM
klf33
May 21, 2008 12:25 PM
johnnychum
May 18, 2007 05:42 PM
