newer tank install 1990 softail
Old May 10, 2010 | 05:57 PM
gartec81's Avatar
gartec81
Default newer tank install 1990 softail
i just picked up a split tank from a 1998 softail. I am trying to install on a 1990 softail. are they compatible. Is there any thing written up on a how -to on tank removal and install?
any help would be great
L.
Old May 10, 2010 | 06:33 PM
gartec81's Avatar
gartec81
TTT+ to the top
trying this job tomm. so I need some help. I tried the search, but only 2000 and up models have pictures and things to help. I am looking at 1990 and wondering if anyone has done the job on here?
Old May 10, 2010 | 10:34 PM
gartec81's Avatar
gartec81
any one have some info on this topic?. Are all tanks interchangable from 1984-1999?
Old May 10, 2010 | 11:53 PM
wlbowers's Avatar
wlbowers
Most aftermarket tanks say 1985 to 1999.
Tank removal is easy.
Have someplace to put the tank down after you get it off
Remove the main fuse
Drain the tank
Get a towel
Remove the console hold down nut
Lift the console up and slide the towel under it
Disconnect everything in the console
If there is a vent hose under the console disconnect it
Cut several 2" pieces of hose the same size as your fuel line. Push a snug fitting bolt into them.
If tank has finished draining remove the fuel lines. Now push the 2" pieces of hose onto the fittings. There's gonna be gas left in the tank and it keeps crap out of the fittings.
Remove the bolts
Lift the tank up slightly and see if there are any rubber bushings under the tank bolts. If there is make sure they go back on during reassembly.
Remove the tank
Old May 11, 2010 | 12:13 PM
gartec81's Avatar
gartec81
thank you very much. if i disconnected the battery(went to buy a new one) is that the same thing as having the main fuse disconnected. or do i still have to disconnect the main fuse?
Old May 11, 2010 | 04:55 PM
wlbowers's Avatar
wlbowers
Naw. Disconnect the battery is better than the fuse.
Old May 15, 2010 | 02:35 AM
gartec81's Avatar
gartec81
thank you very much. got the battery sorted. first time I had to pour the acid in and seal/charge a battery. wish I could have found one local that was pre sealed
this weekend comes the tank project
Old May 15, 2010 | 08:42 AM
wlbowers's Avatar
wlbowers
Remember
We'll be waiting to see them.
angeltrash1
Jan 28, 2018 04:31 AM
mrh1275
Oct 4, 2012 07:24 AM
t059736
Mar 4, 2010 08:00 AM
RocketRocker
Aug 9, 2009 06:52 PM
OneBlackFly
Exhaust System Topics
Jun 27, 2006 03:02 PM
