need help removing reflectors
Old Jan 15, 2012 | 08:28 AM
Napoli's Avatar
Napoli
Default need help removing reflectors
What is the easiest way to remove the reflectors off the trees and sides of my dyna?
Old Jan 15, 2012 | 08:31 AM
Cazimere's Avatar
Cazimere
Heat em with a hair dryer and pull slowly from one end.
Rub the remaining rubber glue off with thumb.
Old Jan 15, 2012 | 08:34 AM
Honey-Badger's Avatar
Honey-Badger
Hair dryer, plastic putty knife or finger nails and WD40 to loosen adhesive and clean remaining adhesive... Use soft cloths...
Old Jan 15, 2012 | 08:41 AM
EP50's Avatar
EP50
Heat them up with a hair dryer. Work a piece of dental floss between the adhesive and the metal. They will come right off. In six months when you go to the dentist and are sked if you have been using floss, you can honestly answer yes.
Old Jan 15, 2012 | 08:46 AM
Napoli's Avatar
Napoli
thanx y'all
Old Jan 15, 2012 | 08:47 AM
CrustySk8er's Avatar
CrustySk8er
I've used a blow dryer then fishing line to slide underneath. It'll come off real quick. The pain in the *** after that is the residue. I used WD40, thumb and an old t-shirt for that.
Old Jan 15, 2012 | 09:17 AM
rooti's Avatar
rooti
I have used some of the methods above...but what works best for me is a hair dryer followed by sliding a zip tie and sawing it down the reflector. Follow it up with some goo gone and it's gone
Old Jan 15, 2012 | 09:22 AM
maddghost's Avatar
maddghost
all of the above, course when i did mine it was a hot sunny day and I just pulled them off slowly with my fingers -- underline slowly!
Old Jan 15, 2012 | 10:21 AM
Honey-Badger
Old Jan 15, 2012 | 10:23 AM
Jackie Paper's Avatar
Jackie Paper
Be sure to keep them. You are not going to believe what they cost and they may be wanted if you ever get rid of the bike...
