06 FLHX shocks on 07 SB
Old Mar 16, 2012 | 05:11 PM
dtone72rss's Avatar
dtone72rss
Default 06 FLHX shocks on 07 SB
I have a pair of 06 flhx shocks on my 07 SB. i weigh 245 with gear. i filled them with 11oz of 7 wt.
Is my fluid level right, and what air pressure should i run solo or two up.
thanks
Old Mar 16, 2012 | 06:02 PM
128auto's Avatar
128auto
Rear air shocks for Dyna:
https://www.hdforums.com/m_1972403/tm.htm
https://www.hdforums.com/m_2445877/tm.htm
https://www.hdforums.com/m_2372126/tm.htm
https://www.hdforums.com/m_3388111/mp...tm.htm#3689316
https://www.hdforums.com/m_3577130/tm.htm
Recommended air pressures
0-10 lbs for a 150-lb to 200-lb rider.
5-15 lbs for a 200-lb to 250-lb rider.
20-25 lbs for a rider with passenger.
FL air preload rear suspension range is 0-35 lbs of pressure.
FLHRS and FLXH low-profile shocks are 0-50 lbs max.
Old Mar 16, 2012 | 07:29 PM
dtone72rss's Avatar
dtone72rss
i checked these threads but could not find a fluid level for these shocks.
Old Mar 16, 2012 | 07:46 PM
p51bombay's Avatar
p51bombay
Since the moco says if they leak they must be replaced there is no specification for oil weight or quantity but others have drained theirs to check the level and while they do seem to vary, you're real close to the mark. If you want more damping then increase the weight, less, put in lighter weight, if there's a bottoming problem you could try to increase the volume a little and the air can go up to 50psi, you just need to try different pressures solo and 2up to see what works for you.
Old Mar 16, 2012 | 07:53 PM
p51bombay's Avatar
p51bombay
Read this one - talks about fluid level and viscosity.
Or this one
Old Mar 17, 2012 | 01:43 AM
dtone72rss's Avatar
dtone72rss
thankx guys. i will give txbowhntrs method a try.
woznotwoz
Jul 8, 2012 05:02 PM
JustDave71
Oct 9, 2011 12:44 PM
712jared
Aug 24, 2010 10:03 PM
SWAZ602
Nov 1, 2009 06:19 PM
Joe Mark
Nov 5, 2007 05:28 AM
