Switchback FLD Front Disc Reason
Old Apr 8, 2012 | 11:08 AM
FLD4sure's Avatar
FLD4sure
Default Switchback FLD Front Disc Reason
I've heard some criticism about Harley only putting one disc on the front wheel of the FLD.
I had another bike (by manufacturer who will remain nameless) that had an aluminum black cast wheel also, and they purposely put only one brake disc on the left side for esthetic reasons.
It shows off the rims and looks better. Possibly Harley had this same reason in mind.
Function gave way to style in this instance.
I'm glad they did.
Bill
Phoenix, AZ
PS - I do use a little more rear brake to balance the stopping, but I also did that with the other bike.
Old Apr 8, 2012 | 11:16 AM
norton's Avatar
norton
One disc or not, my front brake sucks. Brake lever goes almost to the grip sometimes. Does your do that?
Old Apr 8, 2012 | 12:17 PM
FLD4sure's Avatar
FLD4sure
No, about 1/2 way, maybe there is a problem with yours somewhere.
It is too weak of a stop if I use only the front brake, so I probably do a 50/50 squeeze.
I've ridden other bikes where I could do 75% front and finish of the stop with front and rear, but the FLD (like other looks over function bikes) needs a more balanced brake technique to stop quickly and confident (even with our ABS).
Bill
Phoenix,AZ
Old Apr 8, 2012 | 12:24 PM
ConnMan's Avatar
ConnMan
The stock brakes on a Dyna are adequate. Nothing more.
Form over function is rarely the correct choice.
Old Apr 8, 2012 | 12:40 PM
MrPappagiorgio's Avatar
MrPappagiorgio
I think the wheels on the FLD are worth showing but the dual disc system on my Fat Bob works very well. Don't think I would want just one disc doing 80% of my braking. That is one of the reasons I went with the FXDF over the FLD.
Old Apr 8, 2012 | 01:25 PM
Buch's Avatar
Buch
2 time fatbob owner. the brakes on the thing is lovely. i just love it, i need very little effort to make it come to a halt. But i noticed on my 2012 with the ABS the comes further down but i garantee you its a good feeling you know its not gonna lock up
Old Jul 28, 2012 | 11:19 PM
DEBBIEHD's Avatar
DEBBIEHD
1st Gear
Have your dealer replace the master cyl. Mine was replaced before delivery & solved the problem.
Old Jul 29, 2012 | 12:27 AM
icecaps's Avatar
icecaps
Reading More Posting Less
Bleed your brakes. Unfortunately some Harley brake lines come with factory air installed.
Old Jul 29, 2012 | 06:02 AM
1HD1C's Avatar
1HD1C
^X2---- old thread i know but feel it is pertinant to add that there was a bad batch of master cylinders and a number of us had them replaced under warranty.
they will usually bleed it once first then replace per MOCO guidelines
Old Jul 29, 2012 | 07:13 PM
2011Deluxe's Avatar
2011Deluxe
Wrong again.....but I think that most people are getting used to it by now At least read the recall before posting BS.
