The Plasti-Dip Thread
Old Aug 27, 2012 | 04:32 PM
  #231
Pumba11's Avatar
Pumba11
How about an entire Road King!
I will be doing my own thread when I find some time, but I just couldn't wait.
Old Aug 27, 2012 | 10:02 PM
  #232
Gomoses's Avatar
Gomoses
U-tube clip of dude doing an Audi - informative in technique ideas - he uses a gun, but it's nice to see the stuff in action. I wonder if even spokes could be done this way. Of course, lots more detailed taping off with all the exposed parts, but I found it a good starter point. Also, the plasti-color website has a Gun Metal color that looks good, and another color (can't remember the name) that starts off grey-ish and you can tailor how dark it gets with more coats.
Old Aug 27, 2012 | 10:06 PM
  #233
valter's Avatar
valter
A good friend of mine did his A7 with their kit. the spray gun acted funny, and came out looking like a black tennis ball. make sure your gun is quality if you are going to do it this way.
Old Sep 11, 2012 | 10:22 AM
  #234
Brettfullthrottle's Avatar
Brettfullthrottle
Just tried the stuff on my FXDXT-LOOKED AWSOME! Then i accidentally rubbed my fairing against lower legs and headlight ring when re-installing. Scratched right away. Is this normal? How long should it take to fully harden? I am really bummed....
Old Sep 11, 2012 | 08:42 PM
  #235
HD7585's Avatar
HD7585
It will be somewhat soft for a couple days, Then it will be like a protective rubber boot and is quite tough.......unless you don't have enough coats.....i use 4 coats
Old Sep 14, 2012 | 12:16 AM
  #236
Brettfullthrottle
After another day it seems fully cured. Next time I know to wait! It seems VERY durable!
Old Sep 14, 2012 | 06:57 PM
  #237
coobies5's Avatar
coobies5
Old Sep 27, 2012 | 03:06 PM
  #238
DravenGSX's Avatar
DravenGSX
I did a helmet last night.. my first time playing with the stuff. It came out pretty good, but I pulled a bit off when I pulled the masking tape. I just read on this thread to take the tape off when it's still slightly wet and I'm not sure how this works with multiple coats.
I did 4 coats, waiting about 15 minutes in between for it to dry. By the time I got to the last coat, the bottom coats were dry. How do I take the tape off?
Sorry for the dumb question.
Old Sep 27, 2012 | 05:10 PM
  #239
HD7585's Avatar
HD7585
You can do 2 coats .......pull tape..........re tape ...2 more coats........or all 4 coats and run a exacto knife at the tape before you pull it
Old Sep 27, 2012 | 05:42 PM
  #240
xknucksx's Avatar
xknucksx
I find if i do say 1 real light coat, 2 normal, and the last coating a little heavier you can peel on that one without much problem.
