Oil capacity
Old Apr 20, 2012 | 01:20 AM
ynots's Avatar
ynots
Originally Posted by JT-FXDL
I put 2 quarts in and it reads good for the cold check. The strange thing is, it reads the same for the hot check. But if I put more in, it spits it out into the air filter. It's a very fine line on my bike.
It seems like I read somewhere that if your cylinder head isnt venting properly it could cause excessive oil to enter your ac thru your breather tubes... maybe someone else can pipe in?
2.5 qts brings mine to 1/2 way on the cold check and full on the hot
Old Apr 20, 2012 | 04:47 AM
maddghost's Avatar
maddghost
There is a stopper between the filter and the pan. that tube contains almost half a quart. Only way i know to get rid of that dirty oil isby running the starter without spark plugs.The dirty oil comes out absent the filter, you stop when you see clean oil, and your ready to add the rest of the last (almost half a quart).
Old Apr 20, 2012 | 05:53 AM
wyldspirit's Avatar
wyldspirit
Hell yeh after doing it on a warmed up bike I ended up in a over full bike as well. Ended up pulling the plug and draining about 1/2 quart back out
Old Apr 20, 2012 | 06:14 AM
Bagger Jim's Avatar
Bagger Jim
On the original change, I did use a turkey baster, oddly enough, to remove the extra oil. It just seems funny that an engine that develops that much heat doesn't hold a little more oil. Hell, my Sporty takes 3 qts. Thinking of adding an oil cooler just to up the capacity. Down here you need all the cooling you can get in the summer.
zubaugh
Screamin Eagle CVO Models
16
Feb 3, 2020 01:41 PM
rysonn
Oct 2, 2016 06:00 AM
gjasr1960
Oct 22, 2014 08:13 PM
HKMark23
Oil Archive (no new posts)
Apr 9, 2014 05:01 AM
Doc o
Oct 19, 2010 03:12 PM
