Project FXDXT is underway
Once the tins were all off I thought I was satisfied and into the bike deep enough but that changed again as well when I decided to pull the exhaust off as I have a black TH coming this week. Once the exhaust was off I decided to take a peek at the cam chain tensioners as the bike is at 33K miles and I had access to the cam cover. Boy am I glad I did. The outer tensioner is about half worn and the inner is about to go. It is so worn that the shoe is cracked. I didn't even pull the cam plate yet but I could see this with the plate in the bike. It seems like now is the time for a new carb too, maybe I can pull it off, but I am not really sure right now.
So needless to say I ordered up the Screaming Eagle hydraulic upgrade cam plate with the bigger oil pump and a set of Andrew's 26G cams to throw in. Also I got adjustable pushrods and tubes. I still need to get some lifters. I am planning on going with stock lifters as that has worked well on other bikes that we have.
If I only had the funds for a Mikuni 42 and big bore and heads right now that would be done too and could have saved me some money on the adjustable pushrods and tubes, but that mod will have to wait for a while.
So, I have the tins at paint, new TH in black coming, cams and cam plate upgrade, new inner and outer cam bearings, pushrods, and pushrod tubes. What started as a simple bar install turned into a completely stripped down bike with the exception of the top end.
Added some black mid control brackets. The brake lever and shifter and kickstand will have to be done in black too when the time arrives.
anticipation ensues.
