changing derby cover
Old Jun 8, 2012 | 06:42 PM
Mike650's Avatar
Mike650
Default changing derby cover
when changing the derby cover, do i need to replace the gasket like the baggers?
Old Jun 8, 2012 | 06:43 PM
Gliden's Avatar
Gliden
Good idea to do so. Cheap insurance/peace of mind.
Old Jun 8, 2012 | 07:34 PM
bikebuilderdude's Avatar
bikebuilderdude
Also, not all derby covers use the same style of gasket, your gasket might not work for the new one.
Old Jun 8, 2012 | 07:38 PM
pontiac69's Avatar
pontiac69
Stock cover uses a rubber o ring, thats good for a bunch of times if you remove your derby cover. THe paper style for the aftermarket gaskets should be changed each time, like others said for a piece of mind. Cheap insurance. But i know others will say you dont have to change it. Just a good idea.
Old Jun 8, 2012 | 07:50 PM
Mike650's Avatar
Mike650
well i havent removed the cover yet but im doing my 5k service this weekend and got a black derby cover that i want to put on. so if the o-ring will be fine for a one time (planned) removal i can live with that.
Old Jun 8, 2012 | 07:58 PM
Gliden's Avatar
Gliden
Big tip....if you have t-27 screws on that cover don't try to remove them with a t25 bit.
Get the t27 bit to avoid a stripped head which will then keep you busy for hours instead of minutes. Been there.
Old Jun 8, 2012 | 08:23 PM
8541hog's Avatar
8541hog
If you have the paper gasket you can re-use it many times, I still have my original one after 50k and it still seals just fine.
As far as I know they do not use the o-ring anymore, when I replaced my primary the new one did not even have the groove for it like my original one did.
Old Jun 8, 2012 | 10:09 PM
Baeseman1's Avatar
Baeseman1
What 8541 said. Only I'm at 35k miles on the original...
Old Jun 8, 2012 | 11:08 PM
roscoe2010's Avatar
roscoe2010
Same here, stripped out two of the screws and spent the rest of the afternoon using drills and easy-outs to get her out. Went back in with some stainless allen heads so hopefully won't happen again
Old Jun 9, 2012 | 12:30 AM
ynots's Avatar
ynots
my 2010 had the oring style, its not round, its more like a ribbon. Most aftermarket derby covers dont have the groove so you will need a flat one
