The stock wheel is 17 x 4.5 with a 180/60 17 tire. Does anyone see any potential problems going to a 16 x 4.5 rear wheel with a 180/60 16 tire? I know the "gearing" would have to change because the diameter would be smaller. I was thinking about doing this and adding a few more degrees of rake to the frame. I'm not sure how much this would affect the geometry of the bike. Thoughts?
How do you intend to add a few more degrees of rake to the frame?
Cut and weld. Not by me of course. Have a professional shop do it.
The diameter of the rear wheel and tire should lower the back of the bike 1/2". It should also allow the rim & tire to be moved forward 1/2" if necessary. I'm not sure what the 1/2" lowering in the rear is going to do to the overall rake and trail in the front though. Anyone have an idea?
I lowered my 2011 WG 1" in the rear only (left the front stock) and it rides just fine. I know this is not exactly the same but its close to what your intention would be I assume.
Cool. Thanks for that info. I'm not sure how much lowering the rear affects the rake and trail. According to Harleys site the stock rake on our wide glides is 34 degrees and the trail is 5.2 so I have a baseline to work from. I need to get a hold of a frame geometry calculator. That way I can also see what happens if I had the back bone and down tube both stretched 1".
I'd like to get as close to 40 degrees as possible without making the bike handle like crap.
I managed to de-rail my own thread. Started out about the rear wheel and ended up on frame geometry. A.D.D. much? lol
Seems to me that if your going to all that trouble to increase the rake. You could just lengthen the forks to compensat for the change much easier than changing the wheels and messing with the gear ratio.
