Relocation Kit......opinions need
Old Sep 13, 2012 | 07:52 AM
Vato_FXDB'07's Avatar
Vato_FXDB'07
Originally Posted by JaronB
I like them mounted to my forwards.
Dang it JaronB.... I really like that look as well. How did you mount them? Also, is that bottom picture your bob without a front fender? If So, You have any more pics I could see! Also, pros and cons of removing it!?
Old Sep 13, 2012 | 08:04 AM
8541hog's Avatar
8541hog
The look of no fender is much better, but the practicality is not so much.
Any road debris or water is going straight into your face. If you ride with a full face no problem, otherwise I have always found that it gets old fast, but some prefer it. Sand is the worst.
Old Sep 13, 2012 | 01:03 PM
JaronB's Avatar
JaronB
Here's the thread I followed to get the sigs down there. It's just flat stock steel from home depot an angle grinder, drill and two short bolts that fit the sigs.
https://www.hdforums.com/forum/dyna-...rols-done.html
Old Sep 13, 2012 | 01:13 PM
JaronB's Avatar
JaronB
I took off the fender because the guy that trued my front wheel sucked *** and the tire was rubbing and I just haven't put back on. I'm kind of digging it anyways and I plan on getting a superbrace eventually. There is really no pros about it other then less stuff to clean. CONS would be puddles or if you ride in the rain. When you go through puddles it flings water up into your face at slow speed. In the rain IMO doesn't matter because you're getting wet anyways.
Old Sep 13, 2012 | 02:20 PM
Yellotsacul's Avatar
Yellotsacul
Put mine under the headlight. Used the same brackets that they were on the handlebars with, just had to drill out the holes a bit so the headlight bolt would fit through. Cheap, Clean and Easy
Attached Thumbnails Relocation Kit......opinions need-2012-08-15_21-00-40_499.jpg
Old Sep 13, 2012 | 03:31 PM
Gaffy52's Avatar
Gaffy52
I went with the HD fork mounts and I am very happy with the look - well then I guess I would be!
DJY
Nov 29, 2016 07:51 AM
simmy711
Nov 19, 2012 01:06 AM
deuce06
Feb 18, 2010 11:05 PM
streetbob09
Jan 17, 2010 04:35 PM
warren888
Jun 1, 2008 09:53 AM
