Nighttrain Wheel
Old Sep 30, 2012 | 08:45 AM
Mad Mex's Avatar
Mad Mex
Default Nighttrain Wheel
Hello Guys, greatings from Germany!
Sorry for my poor english, I've a question to my plan to get a 2007 Nighttrain Wheel in my 2009 Streetbob.
I was told that this Wheel has 14mm more Material at the Pullyside and that I've to turn of this 14mm from the Pully.
For me, this seems al little bit to much, the Pully becomes very thin?
Sombody of you have done this and nothing is broken?
My Ride was dynoed with 110hp and 153 Nm Torque without NOS! Don't know what is the power with NOS but it's a little bit more
God bless you
Dirk
Old Sep 30, 2012 | 08:59 AM
8541hog's Avatar
8541hog
I do not know the specifics on your proposed setup, but just throwing out a thought.
You may be able to compensate with different spacers between the pulley and wheel. I run an 07 Softail wheel on my 05 Dyna and it was a straight bolt on with a different spacer.
Old Sep 30, 2012 | 09:06 AM
Mad Mex's Avatar
Mad Mex
Yes, you are right! But the problem is that my tire will not run in the middle when I do this!
I like to drive as fast it is possible, so for me it's important.
Old Sep 30, 2012 | 09:07 AM
07bobber's Avatar
07bobber
Might wanna use a softail deuce rear wheel, the nightrain wheel use a 200mm tire and that's a tight fit alone. But if your mind is set do a search a member fit the wheel u want on his dyna
Old Sep 30, 2012 | 09:18 AM
8541hog's Avatar
8541hog
Without actually seeing it, hard to say. I do remember some Softail pulleys that I have seen often have the spacer built into them, without mounting and measuring I'm afraid I can only offer educated guesses. Good luck with it.
Old Sep 30, 2012 | 09:21 AM
07bobber's Avatar
07bobber
Use 25mm axles bearings spacers and sleeve in place of the 1" parts he used
https://www.hdforums.com/forum/dyna-...-on-06-wg.html
Old Sep 30, 2012 | 10:00 AM
Mad Mex's Avatar
Mad Mex
I will use a 190/55R17 Pirelli Diabolo Rosse on that wheel. That will run without any problems in this fender.
A friend of my have made this but he has the stock power in his bike, so I don't know if this will run with my bike.
The Deuce wheel was a option before, but I get this Nighttrain wheel for very small bucks.
Maybe it is a good plan to change from belt to chain?
BTW: cool link, thank you a lot!!!
Old Sep 30, 2012 | 05:17 PM
SuperFastGlide's Avatar
SuperFastGlide
I have a crossbones rim on mine... I had to remove .250 off the inside of the pulley and .400 off the belt side wheel spacer... after that its an easy fit..
Old Sep 30, 2012 | 05:30 PM
Slipstrm's Avatar
Slipstrm
I put a night train wheel and a 200 on my 07 FXD.
Heres a link to the write up.
https://www.hdforums.com/forum/dyna-...per-glide.html
Old Oct 1, 2012 | 02:25 AM
Mad Mex's Avatar
Mad Mex
Oooh...cool!!!
Thank you so much Guys, that all really will help me really!!!
06SGWA
Oct 1, 2014 12:31 PM
jackie fred
Jul 7, 2013 01:08 PM
Henry89
May 16, 2012 04:05 PM
bpd138
Mar 14, 2011 10:26 PM
rbabos
Jun 14, 2009 01:09 PM
