old bike-low miles. issues?
Old Dec 15, 2012 | 11:08 AM
Puglia10's Avatar
Puglia10
Default old bike-low miles. issues?
Looking at a 2001 bike with 5,000 miles. Anything particular to look for? Are there issues with so few miles? I'm thinking old tires, dry gaskets/seals, etc. Am I right or is it a non-issue? Thanks!
Old Dec 15, 2012 | 11:16 AM
Robbie13's Avatar
Robbie13
LOSER
Wow...that has been sitting more than ridden.
Old Dec 15, 2012 | 11:19 AM
Good_Apollo's Avatar
Good_Apollo
Change fluids and tires, run some seafoam through it and I think you'll be fine. When I got mine it had 6000 miles on it and was a 2000, got it 3 years ago.
Old Dec 15, 2012 | 02:20 PM
Psi23's Avatar
Psi23
really depends on the climate too, check with the owner ask how long since last start. Carbed bike too, probably old gas in the tank and carb. I would have the carb cleaned and drain the tank. You maybe be able to add some stabilizer before starting depending on what the current owner tells you about run history.
Old Dec 15, 2012 | 05:02 PM
Wakko47's Avatar
Wakko47
My '90 Sporty had 2k on it and it was just fine. Check the inside of the tank for rust and smell the fuel for varnish. It may need a carb rebuild and tires (mine did) but it didn't leak a drop.
Old Dec 15, 2012 | 06:12 PM
Austin Dave's Avatar
Austin Dave
Check the date-codes on the tires to determine how long its been since they were made. Any tire 7yrs old/older, no matter how good they look, would be cause for new rubber.
Do the fuel system maintenance as has been suggested. I suspect you will change all the fluids...
Nice find!
Old Dec 15, 2012 | 06:19 PM
Ron750's Avatar
Ron750
I bought an 03 FLHTCUI in January, '11. Had 2k. Dealer changed. fluids, I had them put new tires on.
17k miles put on since then, no issues. Go for it!
Old Dec 15, 2012 | 06:23 PM
RevRaz's Avatar
RevRaz
Mine is a 08 with just over 2k miles, so far so good here.
Atreyu
General Topics/Tech Tips
14
Apr 22, 2019 09:04 PM
mymail10135
Jun 13, 2014 06:12 PM
Kalpish
Jul 11, 2012 11:44 AM
John Hyatt
Apr 28, 2009 01:37 AM
MT
May 8, 2007 12:20 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
