New to the Harley world
I'm coming from a 1100 Shadow ( which hasn't run in years ). Went in looking at the 883 but it was smaller than I expected, I'm 5'10". 220 lbs, didn't even bother sitting on it.
I've clicked 300 miles on it and already have a small laundry list of things I need/want to do. In order of importance
1. Pipes - V&H Staggered Short Shots
2. Kuryakyn ISO pegs
3. Larger Headlight
4. Pro Charger or K&N cone style filter
5. Turn Signal relocation
6. Pull back handlebars
7. Forward controls
1 and 3 are the ones I have questions on.
What is the consensus on remapping after changing pipes. I had two different dealers say two different things. One says yes, must be tuned. Other says no, only when you change the air cleaner.
If I do need to tune, should I just buy a tuner or will this void the warranty ? Will I need to put the bike back stock when I take it in for its 1k service ?
Next question, will the following headlight fit in the tree or will it hit the frame tube behind it ? Worst case, ill get a piece of aluminum flat stock and extend it forward. Do you think this will look too big on the bike ?
http://www.ebay.com/itm/CHROME-KING-...508bad&vxp=mtr
Thanks a lot guys
