2004 Dyna Super grips replacement
Old May 26, 2013 | 11:28 AM
jackal885's Avatar
jackal885
2nd Gear
Default 2004 Dyna Super grips replacement
I'm looking to replace the crummy, beat-up rubber grips on my 04 super glide. I noticed a lot of vendors selling grips without a new throttle tube and was wondering: if I get grips that don't come with a new throttle tube, could I seemingly replace the grips without taking off the existing throttle tube?
I'm asking because for one thing the grips without the new tube are cheaper and for another if I can leave the stock throttle tube on then I won't have to mess with the throttle cables, which is good for me because I'm not sure exactly how to set them back up properly.
Old May 26, 2013 | 04:06 PM
mbutton65x's Avatar
mbutton65x
Yea just cut the old ones off and glue the new ones on. Just make sure you don't get glue between the tube and the handlebar
Old May 26, 2013 | 05:12 PM
dirtdobber's Avatar
dirtdobber
If possible use wd40 under the installed grip. and work the grip by turning it, spray again until the grip slides off.
Doing the throttle cables isn't hard.
Old May 26, 2013 | 10:35 PM
jakenok's Avatar
jakenok
Use hair spray to hold the new grips on.
Old May 27, 2013 | 09:55 AM
jackal885's Avatar
jackal885
2nd Gear
Hairspray is what we used to use on our bicycle grips as kids!
I'm gonna go ahead and order up a set of grips without the throttle tube. Hopefully I wont have to cut the existing grips off, because i'd like to keep them around but they're pretty thick material so it may be difficult to get them off otherwise.
Then again if I cut them thats one less 'extra' part I have collecting dust in my garage..
Old May 27, 2013 | 10:08 AM
skinman13's Avatar
skinman13
I have ISO grips on my SG and I accidentally pulled off the throttle grip when I pulled on it while getting the bike level to roll my lift under it. I glued it back on with Weldwood contact cement. Weldwood contact cement is widely used in aviation because that stuff will glue just about anything...a 3 oz bottle cost about $3.50 and you can get it at just about any hardware store, Home Depot, or Lowe's.
Old May 28, 2013 | 12:38 AM
Shrug's Avatar
Shrug
I installed new grips on Atlas and didn't have to glue the left side. Even though it's a 2004, the newer HD system works. Very convenient,
Old May 28, 2013 | 03:14 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
From the ***Dyna Models & General Service Video Link Index***
Originally Posted by FXD2003Rider
Here's a trick on how to remove a glued handlebar grip:
Old May 28, 2013 | 07:11 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Get the new grips and go to youtube and google Harley throttle adjustment. Scroll down to softail and dynaglide Harley Davidson maintenance video. Mike Durham does a good job of showing you how to adjust the throttle cable and return cable to get the slop and slack out of them. I do this everytime I service my bike and I seem to always have a little unwanted slop in them.
Old May 29, 2013 | 07:09 AM
skinman13's Avatar
skinman13
I did not glue my left grip back on when I changed over my handlebars over the Christmas Holiday. It was tight and I did not think I needed to glue it but it would slip over time and I would find myself constantly pushing it back up so I pulled it off and glued it a few weeks back when I glued the throttle grip back on. It has not slipped since.
RevRaz
Dec 24, 2012 08:37 PM
RocketRocker
Dec 15, 2009 11:42 AM
kelton3
Sep 25, 2008 02:05 PM
rmarion
Dec 2, 2006 04:24 PM
Rick51
Aug 15, 2006 10:51 PM
