Handle bar/riser question for 2003 fxdl
Old Jul 28, 2013 | 06:35 AM
03Custom883's Avatar
03Custom883
My bad they are the right length. They just get routed different. I will be hopefully starting the bar swap today I will post pictures when I'm done
Old Aug 4, 2013 | 06:23 AM
03Custom883
Update: extended all wiring internally wired the bars (2013 are internally wired)
Put the new brake line on bleed it. You can you use you stock 2003 fxdl throttle and idle cables and I did( still have the other ones just in case). Today I have to change the clutch cable and that is the last step. Took a picture of the before and I will have pictures of the after and post them up and hopefully get to go for a test ride as well.
Old Aug 4, 2013 | 05:45 PM
03Custom883
Nash finished up today. You have to change your brake and clutch cable. Your throttle and idle just have to be re-routed and they fit perfect. Tool it for a ride and it feels great. Here are some pics. I have others but my plate is in it so these are the ones I'm posting
[IMG][/IMG]
[IMG][/IMG]
Old May 9, 2014 | 11:03 PM
nashspu's Avatar
nashspu
I know it has been a while but do you remember if you had to extend the wires? I know you said you did but was wondering if it was a necessity or you did it bcuz you had the extensions already. Ordering parts in the morning. I love the look. You used the stock street bob risers?
Old May 10, 2014 | 07:16 AM
03Custom883
Hey Nash yes I had to extend the wires a bit. I wanna say around 5" each even if you run your wires externally. Yes used 2013 stock streetbob risers and bars. And the bars are setup so you can internally wire them which is what I did.
Old Oct 23, 2015 | 08:08 PM
nashspu's Avatar
nashspu
took forever to get around to doing them. an afternoon to put them on but well worth it
Attached Thumbnails Handle bar/riser question for 2003 fxdl-20150907_183519.jpg   Handle bar/riser question for 2003 fxdl-20150907_194046.jpg
fafcpa
Mar 18, 2017 08:19 AM
shishkabob
Feb 15, 2015 05:36 AM
Bocefus
Jul 11, 2014 07:10 AM
BFDHD14
Nov 5, 2013 03:04 PM
jhamm
Aug 21, 2012 11:48 AM
