True Track- does this look right?
Old Aug 19, 2013 | 08:24 PM
Donny's Avatar
Donny
Default True Track- does this look right?
A friend pointed this out the other day. I didn't notice until he said something. The brackets seem close together, but that's how it went together. I installed them along with new motor mounts, and did the complete alignment procedure, before adding the True Track.
Excuse the filthy bike, I live on a limestone and dirt road.
Old Aug 19, 2013 | 08:46 PM
Donny's Avatar
Donny
hmm. Just looked at their instructions on their website, and it looks the same in their pictures.
Old Aug 19, 2013 | 09:27 PM
brandon95354's Avatar
brandon95354
do you feel the true track helped out?
Old Aug 19, 2013 | 09:44 PM
upflying's Avatar
upflying
What is a True Track?
Old Aug 20, 2013 | 06:26 PM
Donny's Avatar
Donny
It works very well.. Do a search, there's TONS of info about them.
Old Aug 20, 2013 | 07:14 PM
HD Pilot's Avatar
HD Pilot
Hey Donny, away from my bike right now but I will look at mine tomorrow if nobody else posts up about how theirs look compared to yours.
Old Aug 20, 2013 | 07:30 PM
ynots's Avatar
ynots
Here are a few pics for comparison. Maybe it will help?
Attached Thumbnails True Track- does this look right?-true-trak.jpg   True Track- does this look right?-truetrackb.jpg   True Track- does this look right?-truetrackbbba.jpg
Old Aug 20, 2013 | 07:35 PM
ynots's Avatar
ynots
its a stabilizer that helps keep your motor from dancing around it the rubber mounts
Old Aug 25, 2013 | 11:30 AM
Donny's Avatar
Donny
Pretty much looks the same.
Old Aug 25, 2013 | 05:44 PM
neilpp's Avatar
neilpp
I just installed a True Track set up this weekend so I'm not sure if everything is settled yet but after a 60 mile ride today I looked at the gap between the front brackets and I'd guess it to be about 1/16" or 1.5 mm or there abouts.
I'd say the TT improvements are subtle but noticeable. A little tighter feeling. I have not experienced the wobble problems that some have had. At most some occasional unpredictable cornering behaviors - I'd describe a them more as lurch while establishing the line on faster corners especially if there's a decreasing radius.
Vibration is no worse, maybe a little different - my front isolator was touching the engine so I removed some material from it to fix this, so that may account for this change.
