fricken stripped bolts
Old Oct 14, 2013 | 06:47 AM
swedefour's Avatar
swedefour
Agree..use propane torch to heat area up - around bolt - then vice grips if you can latch on to it.
Old Oct 14, 2013 | 09:06 AM
DesertDyna's Avatar
DesertDyna
Using the correct tool for the job is also important. rounding off the corners of a bolt is usually indicative of an open end wrench. If you dont have any, I suggest getting a set of "ratcheting" box wrenches. They will keep you from messing up your bolts, and work in tight places where you cant get a socket. Box style wrenches will exert pressure on all faces of the bolt instead of two....so you dont mess em up as much. The really fun ones are when you round out a socket cap head bolt.....
Old Oct 14, 2013 | 10:06 AM
transam7969's Avatar
transam7969
Originally Posted by missedem
all that lock-tite is the only thing that keeps the bike held together. been seeing harleys drop parts for years that vibrated off because no lock-tite.
i'm cool with locktite and use it anytime I do anything on the bike but it would make things much easier if it was blue vs whatever the semi permanent **** is they used, coupled with seemingly soft material of some bolts, it can be a PITA
Old Oct 14, 2013 | 10:51 AM
Imold's Avatar
Imold
I've drilled the heads off several stuck bolts/screws, take off the cover, bracket, whatever, and use vise grips on the exposed section of bolt. Having the head off also reduces some of the "stretch" pressure on the threads, though it won't help loctite or rust much. Worst case scenerio, I've drilled them out and re-tapped for a larger size, but you don't always have that option. I never have problems with a screw I put in; I use either the right grade of loctite (blue or red, never green) or anti seize, depending on the useage and size - no use using loctite on hot engine parts, the heat will soften it anyway. I often coat unthreaded shanks of a bolt with anti seize even when I use loctite on the threads, too, to prevent them rusting in. One of the best ways to avoid future problems is using a torque wrench; few people have a "calibrated" arm, and most that think they do over tighten the crap out of everything. Even a torque wrench is a little vague on actual tightness; a variety of things like temperature, lubrication, quality of thread cutting, can affect the actual torque, and in some highly critical applications, tools to actually measure bolt stretch are used instead of torque wrenches - bolt stretch is a more accurate measure of tightness. I've also replaced some of the Harley hardware with grade 8 bolts, especially when there's a nut instead of being threaded into aluminum. Stainless may look pretty, but it's also pretty weak; there are up to grade 5 or 6 stainless, but you usually won't find them in a hardware store, just soft junk.
Old Oct 14, 2013 | 05:21 PM
skinman13's Avatar
skinman13
+1 on the right wrench.
And, I will add quality tools matter also. There is a reason that Snap-on, MAC, and Proto, are the tool of choice for most professionals. They are built to tight specs and they are expensive. Inexpensive soft metal tools will do in a tight fastener quicker than you think...and getting out a flush broke bolt is a ****!
Most folks would not believe the difference that a quality tool will make over a cheap one.
Old Oct 14, 2013 | 07:53 PM
Junkster's Avatar
Junkster
Cheap tools,soft metal and factory yellowish loctite make for a tough day wrenching. You spent the money on the bike. Spend the money on the tools if you dont already have quality ones. Use loctite sparingly and heat when necessary.
Old Oct 15, 2013 | 06:39 AM
transam7969
I've just got craftsman tools now. Had a nice snapon toolbox full of tools my dad had given me but it was stolen and I can't afford to replace them. The craftsman tools do the job.
Old Oct 15, 2013 | 07:22 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
I try if possible to heat the fasterners before I try and wrench them out.
Romeo
Sep 10, 2025 04:25 PM
johnnyglass
Mar 2, 2016 01:01 PM
JDisME
Apr 13, 2015 02:16 PM
IrishRedneck86
Mar 18, 2012 08:31 PM
Huebie
Feb 24, 2007 08:11 PM
