apes to low bars?
Old Dec 29, 2013 | 10:32 AM
sluginxlt's Avatar
sluginxlt
Default apes to low bars?
well the dyna i picked up has a set of apes on it and i wasnt to fond of the looks but after a test ride they really have to go because they really ruin the feel and handling of the bike. i want to put tracker style bars with only a 2 inch rise on it but i am not sure if the cables and brake line will work. the main concern is the brake like. there is a hard line from the master cyl down to the forks where it connects to the dual rubber hoses. maybe i can re bend it to follow the handle bars or cut it and flare it like a car brake line to reconnect with fittings. any suggestions would be great. if i have to start changing lines and cables i may hold off because i am not sure if im keeping the bike or flipping it in the spring so i dont want to dump money into something that is just my preference of style.
here is the bars now....
Old Dec 29, 2013 | 11:15 AM
8541hog's Avatar
8541hog
Sounds like you answered your own question....
Wait until you decide whether you are going to flip it.
It's a good looking ride as it is, should be easy to sell.
Old Dec 29, 2013 | 01:30 PM
FXD_noob's Avatar
FXD_noob
HERESY!
Anyways, depending on the kind of bars you want to change to, you will have to change cables unless you're running tall risers, but it's all guesswork until you specify which bars you're changing to.
If you're thinking of selling it however, don't change anything. Why spend money on something you'll be getting rid of in a couple months? In the meantime you could move your apes a little more to the back, that could improve the ergonomics.
Old Dec 29, 2013 | 01:48 PM
sluginxlt's Avatar
sluginxlt
i am undecided on selling, i planned to ride it a bit either way just for fun because its a cool bike .but i wont be able to decide if i like it or not riding around easy rider style lol. i ride a buell and thats kind of my style so riding with apes and lowered shocks feels like it ruined the motorcycle. if i kept it i would like bars low as possible to clear the tank and tall rear shocks for more clearance and reduce front rake. so for now if i could put some low bars on it and make the cables on it now work to atleast get a feel for the bike would be great.
Old Dec 29, 2013 | 02:29 PM
8541hog's Avatar
8541hog
You can use the existing cable to try out different bars that are lower, you will just have a few inches of slack.
Old Dec 29, 2013 | 03:09 PM
Alleyn's Avatar
Alleyn
See if there's a chance the stock brake line from a StreetBob will work. Probably a lot of those available, with all the guys wanting to go with sky-high apes.
I know a Santee drag bar, will work with all of the stock hardware (and lines).
Old Dec 29, 2013 | 03:20 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Yeah like was suggested above, try some different bars and use the same cables it will just have a little slack. Nice looking bike though and I don't think I have seen a back fender quite like that. Good luck.
Old Dec 29, 2013 | 05:01 PM
Ridewva's Avatar
Ridewva
Hog's right but looking at the ape hangers that are on your bike now there will be quite a lot of excess cable and hose to temporarily bundle. A dealer replaced the clutch cable on my FXDX with the wrong one, maybe off an FXD, and it looped up a lot. I ordered the correct one and comparing them side by side they was very little difference in overall length.
Yeah those shocks do look pretty short. Changing those and the bars will make a huge difference in feel and handling.
Almostinvincible119
Sep 28, 2016 12:57 PM
UNCCHarley
May 14, 2007 11:52 PM
Supergo
Apr 18, 2007 11:43 PM
bensonjv
Feb 28, 2007 02:04 PM
