Engine Build Time
Old Jan 26, 2014 | 08:30 PM
  #201
mattVA's Avatar
mattVA
What'd you use to remove the 4 engine to transmission bolts? I had to buy crows foot wrenches to torque those down due to clearance issues.
Old Jan 26, 2014 | 08:36 PM
  #202
soft 02's Avatar
soft 02
Softail is easy. 1/2 wratchet wrench.
Old Jan 26, 2014 | 08:37 PM
  #203
soft 02's Avatar
soft 02
And no gasket to leak.
Old Jan 26, 2014 | 08:42 PM
  #204
HD Pilot's Avatar
HD Pilot
I used a simple hand wrenchmy heavier duty ratcheting wrench with its' big head area did not fit well without rubbing. I have already bought those crows feet for some other project so should be good.
Old Jan 26, 2014 | 08:44 PM
  #205
HD Pilot's Avatar
HD Pilot
Yeah, I was going to ask Matt about that, I guess 2009 has a gasket there?
Old Jan 26, 2014 | 08:53 PM
  #206
HD Pilot's Avatar
HD Pilot
OK, I am working from Photobucket.com instead of my Photobucket Apple App.
Here I have placed a jack under the transmission and have straped the transmission to keep it from moving after I pull the case.
Old Jan 26, 2014 | 09:02 PM
  #207
HD Pilot's Avatar
HD Pilot
Got her out! Because of the dowels that line up the case and transmission that are located toward the bottom, I had to slide the case forward and rotate the case counter clockwise and it still was catching a little on the drive side so with a little tilt of the top toward the drive side - out it came, pretty heavy, guessing close to 80-90lbs?
Old Jan 26, 2014 | 09:06 PM
  #208
HD Pilot's Avatar
HD Pilot
OMG! What have I done
Old Jan 26, 2014 | 10:12 PM
  #209
HD Pilot's Avatar
HD Pilot
In the long run they are right. Now you probably will never have to play with the bottom end again. That is unless you loose a wrist pin clip in the case...
Back in business yet?
Got that circlip installer, but I will close visual check twice at least
Old Jan 26, 2014 | 10:17 PM
  #210
soft 02's Avatar
soft 02
Your right. You better put it all back together and let the dealer do it.
