Engine Build Time
Old Jan 26, 2014 | 07:07 PM
  #191
soft 02's Avatar
soft 02
Nothing better than checking run out after installed and getting .001
Old Jan 26, 2014 | 07:12 PM
  #192
HD Pilot's Avatar
HD Pilot
Originally Posted by mattVA
Alan,
Pull the rotor off. It's magnetic just get a good grip on it. You'll see the 4 screws I'm talking about.
Your a mind reader! I sat down and got my books out and found what you were talking about. I had pulled the case off with all that intact - never read a reference to take that off in the procedure for case removal. Anyway, found the procedure and tried pulling the rotor off and it keeps wanting to snap back - so just pull harder?
Old Jan 26, 2014 | 07:14 PM
  #193
HD Pilot's Avatar
HD Pilot
Man, I am gonna so check that run-out with the fixed crank, hoping to just grin for hours
Old Jan 26, 2014 | 07:16 PM
  #194
mattVA's Avatar
mattVA
Alan,
Get on it with a pair of gloves. It'll come off. You can take the stator off too the Indy will remove it anyway prior to splitting the cases.
Old Jan 26, 2014 | 07:18 PM
  #195
soft 02's Avatar
soft 02
Good time to add some silicon to the stator plug!
Old Jan 26, 2014 | 07:25 PM
  #196
mattVA's Avatar
mattVA
What for ?
Old Jan 26, 2014 | 07:28 PM
  #197
soft 02's Avatar
soft 02
What for ?
To mitigate future stator plug oil leaks.
Old Jan 26, 2014 | 07:30 PM
  #198
mattVA's Avatar
mattVA
Ah you meant the ribbed portion at the case. I can't see oil getting past the cycle electric stator I put in. Nice and tight junction. But good idea.
Old Jan 26, 2014 | 08:15 PM
  #199
HD Pilot's Avatar
HD Pilot
Thanks Matt and soft 02, I got the rotor and stator off. Will put those 4 screws on my ever growing HD parts list!
Man, I am running out of places to put parts, they are everywhere.
I have a question: there are a lot of bolts that come off that do not appear to have any of the HD white thread locker, should I not use blue loctite if I do not see the HD white thread locker?
Old Jan 26, 2014 | 08:21 PM
  #200
soft 02's Avatar
soft 02
Blue for all fasteners except fasteners retaining rotating assemblies (those get red) and light oil on the head nuts.
