Engine Build Time
Old Feb 2, 2014 | 03:15 PM
  #251
senna's Avatar
senna
Originally Posted by alansummrs
I am seeing the 86.0cc to 86.5cc numbers(newer TCs) from a lot of guys who do a ton of builds. I plugged your ~ 86.5cc and my other build info into the Big Boyz calculator and got 10.65:1 static and 9.63:1 corrected - should be real nice for Tman 590s.
Yes, should be great running.
I using Woods TW777, I am hoping for 115+ hp 125+ for torque. Plus the benifit of the trued and ballanced crank, should run so smooth, for a Harley. LOL
Old Feb 2, 2014 | 05:44 PM
  #252
dirtdobber's Avatar
dirtdobber
alansummrs, it's not that we are interested or not. Many of us just read. We know enough to understand without asking a question.
This thread will help many that are considering doing this.
Each person looks at things their own way. Like I prefer SS cams but others prefer other makes.
Question: Are you using the stock rods or go to H series light weight rods
I went through this same thing last winter. Changed cam choices many times. Was going to 107 instead ended going 113. Did the welded crank, and lefty bearing started out going with stage 3 heads ended up going stage 5. Went from a HD 5 speed to a baker OD6 for performance bikes.
I am not a lone, every one (pretty much) changes things up when doing a complete build.
Wise choice on the crank work.
Old Feb 2, 2014 | 07:08 PM
  #253
HD Pilot's Avatar
HD Pilot
I kinda put my comment about whether there were a lot of "learning" type readers for two reasons: 1) the obvious reason, whether there were very many or not 2) to encourage those readers to comment/ask questions - I know if I was reading this about a year ago, I would have been very interested but somewhat intimidated about asking a question, so I wanted those readers to feel more comfortable.
I have yet to read anybody recommend those H-beam rods for a 107" build. I know they must be stronger but no one seems to say they are necessary for my type of build - maybe better for a 117" or so? They are expensive, and the crank work was not planned already so I am already in the house of pain so the H-beams are put over in the too much $$ corner with the 117" decision.
Thanks for jumping in, I am always interested in your posts
Old Feb 2, 2014 | 07:13 PM
  #254
soft 02's Avatar
soft 02
The short comming of the tapered HD rod is if it has a bushing in it. It has a chance to spin eventually. HD stopped using them in the 2010+ models. They are non serviceable. This is why I went with H beams. FWIW.
Old Feb 2, 2014 | 07:25 PM
  #255
HD Pilot's Avatar
HD Pilot
Learning in progress here: I have a 2012 and it looked like my rods had the copper bushings?
Old Feb 2, 2014 | 07:30 PM
  #256
soft 02's Avatar
soft 02
According to HD's dealer updates for 2010 they shouldn't but who knows.
Old Feb 2, 2014 | 08:02 PM
  #257
HD Pilot's Avatar
HD Pilot
I need to double check but I believe my Indy said that John recommended the "Replace wristpin bushings & pinbore to size" for $55. I had told my Indy that if John highly recommends anything then I would do it, so maybe Darkhorse has a good remedy?
Old Feb 2, 2014 | 08:21 PM
  #258
soft 02's Avatar
soft 02
Probably so. My rods were junk so didn't entertain a bushing change.
Old Feb 2, 2014 | 09:26 PM
  #259
hell hound's Avatar
hell hound
i realize this is random and out of left field but i am so jealous of yall's builds. i want to do some engine upgrades too. i managed to do cams a few years ago, but the wow of that has wore off
it is funny because when i here about 107" builds it seems like a monumental leap from my 88", I remember when i was planning my cam upgrade i was considering going to 95" and even considered some 98" kits and that seemed like a big motor to me just a few years ago
Old Feb 2, 2014 | 09:52 PM
  #260
HD Bobber's Avatar
HD Bobber
Some 95 or 98's built well can blow some 106 or 107 motors away. The build all comes down how well the heads were worked the cam and exhaust can flow everything nicely.
