Engine Build Time
Old Feb 28, 2014 | 07:34 PM
  #351
HD Pilot's Avatar
HD Pilot
A little more about the Hayden: Instructions has you shoot for 3/8" from the "floor" where the springs sit to the bottom of the shoe but mine is about 1/4" which has the chain tight. I have read and matt VA has told me that the distance will grow as you "break in" the shoe over time, so hopefully it will get close to that 3/8" target.
Remeasured my crank run-out with the new Darkhorse worked over crank/flywheel and came up with .0013" compared with .0061" before, so should be ready to romp!
Old Feb 28, 2014 | 08:38 PM
  #352
HD Bobber's Avatar
HD Bobber
Yes I have read that too. It will breakin and sit lower, not to mention your chain will stretch a bit with time, so you'll be fine.
Old Mar 2, 2014 | 10:49 AM
  #353
HD Pilot's Avatar
HD Pilot
Hey HD Bobber, did you check your crank after you got it back, just curious...
Got some work done on the cam side yesterday. Had a good look at the oil pump and it looks like new. Installed the pump and new scavenge o-ring as per the HD SM. There are a lot of tips/recommendations out there about how to deal with the oil pump and the o-ring but I just could not see anything that made anymore sense than the HD way. Specifically, I installed the o-ring on the oil pump housing spigot and pressed the housing in and it seated in there with a solid feel as the o-ring went into place.
Old Mar 2, 2014 | 10:57 AM
  #354
HD Pilot's Avatar
HD Pilot
Checked to see how in line the cam and crank sprockets were as per the SM. Although I "passed" the HD spec of less than .010" difference, (I had .008" ) I decided to pull the stock .130" cam sprocket spacer and use the .140" spacer - much nicer!
Old Mar 2, 2014 | 11:12 AM
  #355
hell hound's Avatar
hell hound
nice going
might as well make it perfect
when i did my cams(chain drive) i bought all the spacers hd had then they let me return the ones i didn't use
This is a random comment, but i like the red assemble lube you are using. Seems easy to see how much you got in there.
i just put a good coat of my engine oil on everything, but when do it again i will try to remember the red stuff
almost done!
Old Mar 2, 2014 | 12:52 PM
  #356
HD Bobber's Avatar
HD Bobber
after john's work my run out was .002 from like .007+
Old Mar 2, 2014 | 01:46 PM
  #357
HD Bobber's Avatar
HD Bobber
Just wondering...what's the stock spring pound pressure on factory harley 96" heads? Just curious.
Old Mar 2, 2014 | 01:54 PM
  #358
HD Pilot's Avatar
HD Pilot
I have 2 different #s for stock 103" springs: 130lbs and 135lbs seat pressure that goes up to 310lbs at max lift. #s come from my notes, not sure where I got them.
Old Mar 3, 2014 | 07:13 AM
  #359
rod18cdz's Avatar
rod18cdz
Looking good Alan! This thread is going to help a lot of us. Thanks
Old Mar 5, 2014 | 10:15 PM
  #360
HD Pilot's Avatar
HD Pilot
Back from a 4 day trip, hopefully tomorrow I can make some good progress. Tonight I thought I would take a look at my S&S lifters with the HL2T spacers. The black spacer seen on the left side of picture prevents the lifter from collapsing during high rpms and during engine start. The spacers take up .115" of the normal .200" lifter travel, so when you adjust the pushrods you bottom out the lifter then back out 1 turn(S&S Quickees) which is .031", a little short of the middle of the travel available(.085").
