Engine Build Time
Old Feb 25, 2014 | 09:58 PM
  #341
soft 02's Avatar
soft 02
Originally Posted by senna
You'll be fine, the odds are in your favor. The failures are a small percentage, just like any other part if you think about it!
Old Feb 25, 2014 | 10:06 PM
  #342
HD Pilot's Avatar
HD Pilot
You are right, I second guess myself all the time - just going to move on and forget about it.
How you gonna break in your bike? I'm still a little undecided, leaning more towards the few heat cycles then just changing the rpms a lot but pushing it without overheating.
Old Feb 25, 2014 | 10:12 PM
  #343
soft 02's Avatar
soft 02
S&S break in method. IMO.
Old Feb 25, 2014 | 10:56 PM
  #344
senna's Avatar
senna
Probably the same, a couple heat cycles check things over and go for a ride. Ride it like you plan on ridding normaly, no constant rpm's for a couple hundred miles.
The only thing breaking in are the rings and they are broke in in a couple hundred miles.
Old Feb 27, 2014 | 12:17 PM
  #345
HD Pilot's Avatar
HD Pilot
One characteristic of my threads is I will not hold back if I embarress myself ,so here is another tip for noobs engine mechs:
I read a lot of threads but never heard about making sure the primary chain is held up when you tighten down the compensating nut. I was having difficulty installing the Hayden tensioner and notice the chain being stuck on the compensator side. Anyway, had to pull out the brand new compensator bolt to release the pressure, guess I will be heading to the HD dealer to pick up a new bolt tomorrow. The Primary Chaincase housing gasket lip still looks good to me, there is a fairly wide unscratched area on the outside edge that should seal easily. I have a flat sharpening stone to smooth out any burrs and I might hit the rough inner area with a some gasket sealer
Old Feb 27, 2014 | 12:24 PM
  #346
mattVA's Avatar
mattVA
Oops. My surface looks just like that adjacent where the tensioner goes and it isn't leaking. .no extra sanding or sealer done. I think wrangling the tensioner in marked mine up.
Old Feb 27, 2014 | 01:00 PM
  #347
Black Bart's Avatar
Black Bart
Alan, please keep these little tidbits of wisdom flowing to us, they certainly share with us the benefits of your experiences. When I bust open my primary to install the Hayden tensioner on my bike, if I remember this sage advice, then I should not be prone to the same outcome. Thanks again for providing us with the photos and detailed explanations, it's the best supplement to the service manual that any of us could hope for.
Old Feb 27, 2014 | 03:51 PM
  #348
HD Pilot's Avatar
HD Pilot
Thought I would move over to the cam side until I get the new compensating bolt:
Used the Heartland Bearing Install Tool, worked great and very nice instructions although they do not remind you to have the bearing lettering facing out.
Here is the set-up:
Here they are both in, a really easy process compared to other things on this build.
Old Feb 27, 2014 | 04:14 PM
  #349
Tat2u's Avatar
Tat2u
Originally Posted by soft 02
Its a shame they dont have one in black. With a 2" tank lift that would stand out too much on my bike.
Just wrap some black electrical tape over it maybe to hide the white?
Old Feb 28, 2014 | 05:29 PM
  #350
HD Pilot's Avatar
HD Pilot
Installed my new compensator bolt and torqued it with the lower portion of the chain held up so I could avoid pinching it like last time.
Installed the Hayden tensioner also, need to compress that thing as much as you can then zip tie it.
