Engine Build Time
Old Mar 6, 2014 | 06:36 AM
  #361
mattVA's Avatar
mattVA
Leaving no stone unturned. .I appreciate the lifter breakdown pic
Old Mar 6, 2014 | 06:43 AM
  #362
soft 02's Avatar
soft 02
Alan. Were you looking for a clutch hub or was it someone else?
https://www.hdforums.com/forum/touri...-assembly.html
Old Mar 6, 2014 | 06:59 AM
  #363
hell hound's Avatar
hell hound
I was looking for one. I found my basket was worn where the plates slide. Not too bad and i already but it back together, but i will be needing it sometime soon.
I sent him a pm. thanks for the post.
i assume that is a direct replacement for my 06?
Old Mar 6, 2014 | 07:01 AM
  #364
soft 02's Avatar
soft 02
It should be.
Old Mar 6, 2014 | 07:09 AM
  #365
hell hound's Avatar
hell hound
nevermind, i needed the shell
no coffee yet
Old Mar 6, 2014 | 08:28 AM
  #366
HD Pilot's Avatar
HD Pilot
No clutch hub needed but per Matts' recommendation, I bought a Snap On socket for the 11/16" clutch jamnut. I have been using the crowsfeet wrench and it has been a pain, think I will like this tool a lot.
Old Mar 6, 2014 | 08:40 AM
  #367
SLV's Avatar
SLV
Great thread Alan. I'm learning a lot.
FYI, you may already know this, but using a crows-foot on a torque wrench modifies the torque value and renders the setting incorrect. Using the crows-foot and making the brake-arm length longer produces more torque than the setting. To get the right setting, measure the length of your torque wrench from center handle to center drive. Then measure the crows-foot from center drive to roughly center bolt (or whatever you are torquing.)
Determine the percentage of overall wrench length you are adding with the crows foot, then back the torque setting off by that percentage. As an engineer, I always cringe when people over torque fasteners without knowing.
Being a seasoned mechanic, you probably already know this, but it doesn't hurt to throw it out there.
Old Mar 6, 2014 | 08:59 AM
  #368
HD Pilot's Avatar
HD Pilot
Thanks SLV, this is why I try hard to use a crows-foot at 90 degrees - no torque adjustments! Can not always get away with 90 degrees though....
Old Mar 6, 2014 | 09:30 AM
  #369
mattVA's Avatar
mattVA
I'm pretty sure no one torques that clutch jam nut to a spec. .too hard to do so. Snug it up and I think it will hold fine. Alan that's one of those tools that's nice to have, glad you bought one.
Old Mar 6, 2014 | 09:35 AM
  #370
soft 02's Avatar
soft 02
Put a normal nut on it and its not so bad. I still use an opened ended wrench and an allen socket.
